Frankensurf
Keep ya head down, mate. Amazing how it cranked up to cat 4 since yesterday. Hope you get through it okay.Oh.
Wish us luck in Yeppoon tonight we have a Cat 4 Cyclone 250+ km winds...
The temp sender in colrado and dmax like Alison and other ecu transmisions is accurate to the deg. you can trust them . even with a ir temp gun its spot on the money . In my case the colraodo transmission ecu over temp switches on at 130 deg and remains on until it drops below 120 . I was after vehicle percific trans temps on Colorado automatic owners . I have a trans cooler . I also have a heck of a lot of wind resistance having a 2 mtr wide tray and total height of 2.4 mtrs all boxed in like a pantec truck .We run proper temp gauges on autos at work! Don't always believe scan gauge they take the temp from a sensor that will not give you a real time reading. We run synthetic oil in transmissions. Just as a point transmissions run between 80 to 100 once you hit around 115 or over the best thing to do is pull over and put it in park let it cycle and cool naturally. A proper trans cooler is always a good idea.
If the sensor doesn't give a real time reading, how much of a delay is there? When I start drivng up a steep range, the Scanguage temp reading starts to climb immediately.We run proper temp gauges on autos at work! Don't always believe scan gauge they take the temp from a sensor that will not give you a real time reading. We run synthetic oil in transmissions. Just as a point transmissions run between 80 to 100 once you hit around 115 or over the best thing to do is pull over and put it in park let it cycle and cool naturally. A proper trans cooler is always a good idea.
It does give real time temp . that's its intended purpose . he does not know this well he does now . I can see a hill look at the temp and immediately see a rise in temp on the scan gauge as I ascend.If the sensor doesn't give a real time reading, how much of a delay is there? When I start drivng up a steep range, the Scanguage temp reading starts to climb immediately.
Tink
That's awesome its all about the same ranges as mine . when I don't have the double decker camper on.Just for clarity, I have the current model in which the auto "apparently" runs cooler. I also have an ARB bullbar and underbody protection. Both of which reduce airflow slightly.
Normal running, on flat highway, at 30 ambient temp, between 85 and 87 coolant and 83 to 85 auto trans temp. On a cooler day, the coolant is about the same but the auto temp can drop 10 or more degrees.
Hit the offroad tracks, or a steep incline, and the coolant climbs to the high 90s and the auto temp to around 110.
Only once, offroad, uphill, and in low range, did the auto temp light come on. Manual says to park and idle engine, which I did.
Tink
Muck That is the general idea! But the best place to pick up the exact temp no matter what box you have to be %100 accurate is where the trans oil exits the box to the cooler not in the box or at internal ecu with these trans. That is why we run our own made up sensors at Wholesale Automatics. We have had a hell of a lot of variances with many transmissions like these. With the change over to synthetic make sure you flush it as best you can if you are changing from standard oil to synthetic. I try to spread the word that 120 is time to pull over and let the auto cool to many people go by a reading that is not %100. Both our scan tools are close but never accurate. Also our nomad valve bodies help the flow for towing and help the trans a hell of a lot.
Cheers Bruce
Not trying to sell you anything but here is the link with a bit of info. I'm sure if any Earthers want our gear I'm sure I could help out with some trade prices to members
Temp gauge
https://automatictransmission.com.a...emperature-gauge-to-suit-isuzu-d-max-5-speed/
Valve body
http://automatictransmission.com.au/nomad-extreme-and-full-manual-valve-body/
Cheers Bruce
Temp gauge
Valve body
