Auto and manual?
canyonaro MK1
i feel like a bit of a doofus for posing this question, but, i'm doin it anyway. It's buggin me and i'd like to know BEFORE i get into a situation.
I have a manual. always have had. i have oodles and oodles of hours 4wheelin under my belt in a manual, i understand the whole hill decent technique of no pedals just let it crawl and use the compression to hold it from running away.
However, i am about to take delivery of my new (well new to me!) vehicle but it is an auto and i am wondering if anyone can offer some pointers with regards to hill decent. Not being able to stall the engine by using brakes without the clutch concerns me, as this was always my "worst case" plan. Stall it, stop and re think what is goin on before i go off that edge! Are the auto's geared extra short in low range 1st to compensate for this? it is not a modern truck with electronic gizmo's (like decent control or traction control) it's just a meat pie 98 paj.
__________________
GippsSurfer
bit of practice wouldnt go astray...
ive got a hilux surf (Diesel) AUTO... i find in Low Low, it crawls down nicely, dont have to touch the brakes for MOST tracks that ive been on... (Spud Spur Trk comes to mind as a place where i WAS on the brakes the majority of the way though...) I spose its really just getting used to letting the car run that 1st little bit to let it catch itself (if thats what its going to do, mine does...)
Petrol motor will probably run away on you, diesel, like mine, not so much...
hope that helps...
croozza
Just drive it like a manual, change the gears manually, as you will hardly ever use "D", if the car is equiped with ABS, dont be afraid to keep it in high range 1st gear for steep desents, and let the ABS do its thing, (ABS will turn off when in low range), but having said that, you can still use low range 1st gear for desents, (try both and see what your most comfortable with). Hill climbs is the autos strongest point, as you can just give it enough power to crawl over rocks/obsticles as your not having to keep up revs or slip the clutch, but basically just go out and try some easy stuff till you know what the vehicle is capable of, I bet after a few trips you will wonder why anyone would want a manual.
red hilux
I have a 3litre diesel auto surf and I love it for rocks, beach and towing. No need to worry about gears in the sand, just hit the go and stop pedal and the car does the rest.
Steep hills has already mentioned etc
One down side to an auto and in sand, if your pushing hard on soft sand the engine will heat up quicker compared to a manual, reason being is the tranny gets its cooling from the radiator, in turn heating the radiator up quicker. Easily resolved, run in low range in soft sand, and regardless of what ever your doing, fit a big external tranny cooler.
Another thing to consider in learning about your car is to join a paj forum
allanmac
As Croozzer said, use the gears whether descents or ascents. I have a Paj & fact is they tend to run away as gearing is nowhere near as low of that of a manual & you will have to use the brakes on steep descents more often than not. One thing that is a 'must' in a auto, especially earlier ones without hill descent assist etc, is to learn how to left foot brake.
By learning this technique you can also learn to 'drive through the brakes' which some people rave about but I never particularly liked. Also the ability to 'LFB' is advantageous on steep climbs, especially in a IFS vehicle, where you often lift a front wheel & all the power is transferred to wheel with least resistance. A little bit of brake helps stops this.
cptmud
in an auto, it pays to learn to drive thru the brakes on steep decends
Here's the gist of it, see if you can get the hang of it after a bit of practice.
Basically you select low first and apply modest, steady pressure to the brake with your LEFT foot. Enough to hold the car with the handbrake off, then gently apply power and the car will move slowly in a very controlled way, in fact dead slow if you want. If you lift off the gas and it gently stops then you have about the right brake pressure. On muddy slopes you will need to keep on enough power to keep all the wheels turning slowly and steadily whilst keeping absolutely constant pressure on the brakes.
A few of things happen when you use this technique,
1. you tend to fool the open diffs into seeing very similar torque across the axle so you get a very even drive across axles, particularly true on the front axle where your brakes become the dominant load on the axles, not the tyre grip (or lack of it)
2. you get all four wheels receiving very close to the same drive torque and nice and slow. You can suddenly feel the car biting on all four wheels insead of slipping and sliding as it will do if you attempt to roll down the hill on brakes alone.
3. your torque converter is slipping heaps (you are forcing it to) but your engine rpm will be somewhere around 1000-1500 (not at idle) and that usually means the torque converter will be trying hard to connect engine & tranny .. this is one you would have to ask an expert about, but I have heard claims that this is one of the reasons this technique works so well.
frequin
I just had this debate, upgraded from a 5spd manual lexus v8 hilux to and 2011 v6 auto! best decision I ever made if you ask me!
