Make sure you use a gas mig not a gasless.
Justin
Why not? Do gas migs do stronger welds?
Look i'm a fitter not a boiler maker, but I weld all the time. I believe gas mig is the go. Gasless is shit. Arc is good, but this Comes down to the quality, I've used little inverters that are sensational, and then some that have no duty cycle at all. what I would do is, spend a weekend cutting everything out, get everything ready, then hire a decent quality mig and weld it up all weekend. Buy a cheap welder and you will struggle to get motivation to do any welding, as it'll look like a flock of birds had randomly shat everywhere, get a good welder and you'll be bragging to your mates!
Use ARC or GAS MIG. They both have their positives and negatives. In the right hands, they both do very good welds. Never use gaseless MIG. In my own experience, Arc is great for outdoors and MIG is good for indoors/no wind outdoors.
The key is to use a good quality unit and also have a lot of spare metal to practice on before touching your project.
The only problem with gas is you need to hire the gas bottle if you buy a mig and then would you get future use from it etc etc,unless you hire a mig to do the lot...
Arc welding is fun and once you practice a bit you can get quite good at it without blowing holes in the steel.....![]()
Yeah blowing holes in the steel is fun too! When I first started -- after the chook poo stage -- I thought my weld was going very well, I took the mask off and I blew a hole through the steel and managed to weld the project to the metal table. Come a very long way since though.
With both, I reckon you need to do an intro course or have an experienced person there to show you how it is done -- to get correct speed, penetration, safety and minimize warp. Those stress tests are fun to do.
In terms of safety, it's amazing how those Chinese workers do ARC with a garbage bag and sun glasses. You may as well rub your eyes with 100 grit sand paper.
I do a lot of welding in my job and agree that a gasless MIG is a waste of time. If you have no experience in welding get someone else to do the job. Gas MIG welders are expensive. An ARC welder is much more affordable and you can buy quite compact units these days. They are a worthwhile addition to any shed. Maybe if you get some instruction in the use of an ARC welder and practice on smaller jobs until you become more proficient.
I like the trolley. Quite similar to the one I use for ARC/TIG welding.
