ARB tow bar hitch
Shane Dunstan
G'day,
Just wondering if anyone else has come across this & what they did- I assume lots of times.
I've just changed tow bars from a std Mitsubishi ( Triton) to a ARB. No problem there.
But my old hitch does not lock in the tow bar housing as the hole in the ARB bar is further back. ARB have a after market one on their shelf that would be OK I guess but its only rated at 3.5 t ? where the other system is 4.75 t. Maybe not a big thing , but I felt it was a step backwards.
Anyone else come across this before...?
Shane
0406 787473
First of all, a triton only has a legal towing capacity of 3 tonnes
So doesn't matter what gooseneck you put on as long as it is rated to 3 tonne or more
It is not a step backwards if you don not tow anywhere that much anyways
marty e
The arb rear bar comes with a tow hitch I would be asking where it is and why they did not give it to you
Shane Dunstan
G'day - yep got the tow hitch, sorry I should of explained better. Its the hitch the goes in place of the tow hitch that you put your snatch strap on. But thanks anyway.....Cheers Shane.
Shane Dunstan
G'day Marty, just looking at your photo's - wow, very good....;-) Your vehicle is very similar to mine, so I'd be interested in your advice on what you did re the rear hitch. Not the towball tongue part - but if you have a hitch that replaces that for attaching a snatch strap. Cheers Shane.
Toddyh
The hitch you are talking about is called a recovery hitch. Can buy them all over the place from ebay to 4wd shops to supercheap auto.
marty e
The rear arb bar has two eye bolts witch are rated use a equalizer strap to both of them no need for a recovery hitch what so ever
Gavo
Yeah I know what you mean about hole been back. Pain in arse. Kaymar do it as well. Meant my bike rack required modifying to fit and my recovery hitch D shackle hit square before i could get pin in.
I actually cut the square tube back 15mm. I'm not sure what their reasoning is to move hole.
No man ever cut himself bearding!
EffieC
Would it have been easier to re drill the hole in the 'recovery' hitch than to have cut the hitch tube itself, or have I misunderstood which part you cut? :(
Hi Todd
They won't fit mate, this has come up on another forum about Kaymar bars too.. Seem ARB sell Kaymar its designed so you buy there products only not generic..
Gavo
Hi Todd
That's why I trimmed front of mine off. Not having generic stuff fit by moving the hole, imo isn't fair game.
Too right mate ;), it's very sneaky, especially when people are not told about it .My Kaymar bar is around 04,so anything fits, looks like there strategy to go this way was fairly recent as a guess but could be wrong...
Mattzz
Apparently this one fits the ARB rear bar.
http://www.tjm.com.au/en-oceania/product/tjm-recovery-hitch?tid=966
Ironically, ARB don't sell one that fits, but their opposition does.
This one definitely fits.
http://www.extremelimitsoffroad.com.au/winch-recovery/recovery-equipment2013-10-16-08-17-22/recovery-hitch-with-4-75t-bow-shackle.html
If you're not already a member......I'd highly recommend you do
For all things triton....... www.newtriton.net.
Mattzz
Don't count on it.
Some of the earlier ones weren't reinforced behind the eye bolts and were NOT rated for recoveries.......this was later changed but the bar design stayed the same.
So it might pay to check before you hook up an equaliser strap because there is no way of knowing unless you stick your head underneath to check.
GregPS
Not sure how off topic this is ...
I can see the convenience of this hitch, and I also see that the first thing that failed on a destruction test was the hitch pin at nearly 15 tonnes.
My newb question, after reading the many no no's on using a tow ball, why not attach a recovery snatch strap direct to the hitch pin?
Greg
Toddyh
That does work but loads the pin differently to how a hitch does. Also is usually a pain to get the strap in there fr enough and then try to get the pin through. Proper recovery hitches are a much better option for $50.
ARB4x4
Don't count on it.
Hi guys, the eyes on the rear step tow bars are towing eyes only and aren't rated for snatch recovery.
Cheers, Sam.
