ARB fridge freezer
snowy100
any one seen the new 47 litre arb fridge advertised on there website could be worth a try am looking for a new one :cool::cool:
magoomba
Hey Snowy, We used two on the weekend. Well I didn't but my mate that works for ARB did. it a great unit and holds heaps. He has six in his tribe and they held heaps/ On was used for food and the other one was used for ... dare i say it ...BEER. And i think he said that there well priced compared to the Ingel 40 litre? was dunk at the time he told me ..lol but i think thats what he said.
jkm05
I have seen one and they look really good. I have a 110ltr Waeco and we are wanting a smaller one as well so we are considering the ARB one as well as the waeco one. They look really good!
siukalo
Thought i read somewhere about those new arb ones uses danfoss compressor now not more engel..anyone confirm this?
Quozie
Hope they work better than the Engel, I saw an Engel against the Waeco on the Dog Run and the Waeco out performed the Engel hands down with the heat we had, the Engel struggled to keep food cold where the Waeco kept icecream (I know! Who wants icecream camping, kept the Beer really cold too) frozen.
Pure Yobbo
Really - the only time we have had trouble was in SA in 40 deg heat when it was under the torneau cover. put it in the shade under a tree took the cover off to give it some air and down she came.
We had just loaded it up to which would not have helped.
snowy100
used mine for a bit of time now have insulated bag but seems to work excellent had to make up my own fridge slide but think all should be good
knot_gillty
Hey snowie, how do you tie the fridge down? I'm thinking of doing something similar but need to cut one side of my drawers down first...:eek::D
snowy100
the fridge has 4x6mm threaded holes underneath where the feet are i lust used them , would be a pain if you where gunna take it out all the time but if it lives there it liiks neater
4wd firey
Engel VS Waeco
I did a 3 month trip soem years ago - I had an engel without a second battery - NO WORRIES at all worked well - did not letme down.
Mate had a WAECO - with a second battery (obvioulsy not a good battery set up) but woke to many flat batteries and ruined fridge contents.
Adventure guy
Engel VS Waeco
Waeco have a battery saving setting, you can activate so you don't drop your battery volts under a pre-set level, Engel do not, it's an option you can buy to add on to your Engel.
He should have read the manual.
I'm not going to get into the age old dispute, about Engel V Waeco, I have both brands and both have their own merits.
I also like Toyota AND Nissans, whats wrong with me ?? I am open minded !
bmurray2250
Any fridge that needs a battery to run overnight will cause issues on a single car battery. Either use a 3-way fridge or add a second battery which can be seprated from your main cranking battery. A simple relay to switch off the charging if the engine isn't running and wiring to the back of the 4by is useful. If you are doing this all the time, getting a aux battery fitted would be better.
rodw
With the exception of engel, most 12 volt fridges use the Danfoss BD35 Compressor. My 35 litre Waeco has the same compressor as some of the boating and caravan fridges that are 130 litres. From what I can work out, the difference in the power counsumption comes down to the amount of insulation applied. from all accounts it is a very good compressor, just how it is used is what defines how good the fridge is. seriously considering fitting a fridge with a door in the back of may car, A lot cheaper than the car chest frdges and my research has pretty well debunked the thought of loosing cold air all the time.
