ARB Aux fuel tank - what to do
red hilux
My car is booked into ARB on Friday morning to get an auz tank installed.
The tank has a Y peice installed that will feed the main and auz tank while Im filling up.
The problem is ( thanks google ) the aux tank feeds the main tank by gravity feed it thru the diff somehow and then under the main tank thru a banjo bolt.
All well and good if you dont go off road. My main tank bash plate has a few battle scars and even the drain plug has a couple marks. I see a big problem with me smashing this off as it will now be lowered 30mm say. Lowering my drain plug by 10mm will make it inline with the bash plate.
I rang and spoke to the sales guy today ( tried to speak to an installer but they were busy ) and he basically said that they have to do it via the instructions. I know they should be doing it that way, and I know that they can get permission to change the way its installed.
My solution was to just drill a hole in the Y piece and braze in another bit of pipe thats on the main tank filler side. I already have a transfer pump fitted and already wired in from my last aux tank that would never stop leaking.
Im thinking that If I dont get what I want or even another way that I can get full use of the tank and not hinder ground clearance, then its a hazard to my 4wd and 4wd experience and I wont be installing the tank.
80lover96gxl
Can understand your concern mate. Any aftermarket component that hinders ground clearance will likely create issues one way or another down the track , especially a fuel tank considering the potential for fire if damaged bad enough.
Other than modifying it yourself to your satisfaction, and if ARB cant do it I wouldn't be happy with the product, considering its a reasonable outlay of $$$.
frosty
If in doubt, PUULLL OUT!
Someone will have or can make what you want. If your doubting now, you'll never be happy with it!
Sounds like a crap set up anyway.
muc the truck
The best way out of this Is to hard wire a fuel gauge to to the aux tank and hard wire a generic submergible efi fuel pump in the auxiliary tank and simply flick a switch when you emptied the main tank to have the efi pump fill the main tank . I don't like under slung gravity bridges on tanks the hose gets caught up . It will take only a few minutes to transfer fuel and you can do this driving along just don't run it dry. any auto elec could wire it up so while transferring it switches over the aux sender to the dashed factory fuel gauge and use factory low fuel warning light so that you don't run the pump dry in aux tank .
you can use metal hole saw to cut the whole and make a fuel pump/sender holder out of tyre iner tube , steel with welded bolts with nuts that screw on from top torqued down to 8nm as I did when I converted this diesel tank to petrol . This is a jackaroo fuel pump and sender .
http://www.4x4earth.com.au/forum/ja...nge-tank-into-petrol-jackaroo.html#post348730
red hilux
for 1100 bucks installed, I dont want to be having to do anything to it. ]
The tank is 800 (show special)
install is 300. If Im going to modify this myself, I will just save the 300 and do it myself and not pay for half a job.
For once I just want a drive in drive out service and not have to fiddle and tinker.
Im sure I will be happy if its not a gravity fed tank.
Muc, I do like your tank work.
Kirkster72
mine isn't arb (lra) & they use this for filling
Chatty
I have a Long Ranger in the Paj - the filler has two pipes which the bowser nozzle goes in, so you can choose to fill whichever tank you want individually.
Transfer from the aux tank to the main is by pump which pumps up to the filler neck for the main tank.
It works well and I've never had a problem.
red hilux
Can you think if any reason that I can't use the main tank breather pipe as a filler pipe??
It's about a 12mm pipe. I'm thinking another alternative is to put a 3way t piece and then pump into that.
red hilux
Pulled out and getting my deposit back. They have to do it the wrong and dangerous way as per the design rules/instructions
Chatty
Sorry, I should have said, my set up uses the breather pipe to pump into the main
red hilux
Yeah, I asked then about that today.
Answer is no. They will not do anything else other than the fitting instructions.
He said that if I want, let them do the job and then change it later. I said I'm not paying that money to be re doing the job myself.
So, not doing any of it.
Sounds like your doing the right thing, even if you wait to get more suggestions ,info etc
muc the truck
good move now you can get something with no hose to tear off.
