Anyone using a B.E.S.T. Inline Water Filter? Are they safe?
Tony_J
Hi, I am looking to buy an inline water filter. I came across the B.E.S.T. branded ones. Quite expensive but if there claims are true, this would do the job. I am concerned though about the silver coated crystals in it. The claim is that the "silver safe" technology kills bacteria and other bugs.
My main concern is whether this silver could lead to argyria (a condition where your skin and other soft tissue turn blue-grey. A bit like a smurf!). Apparently, colloidal silver does kill bugs but does cause argyria. The maker claims that this filter WONT cause this condition, he doesn't explain why but I guess it is because the silver doesn't 'dissolve' into solution. Colloidal silver is a suspension of submicroscopic metallic silver particles in a colloidal base. If it doesn't, how can it kill the bugs?
I'm soon to do a trip up the CSR and thought that this filter would be the bees knees to purify drinking water from the wells. Now I'm having second thoughts.
Anyone with first hand experience with these filters?
TIA
Tony
mac_man_luke
I wouldn't have thought the silver would be dissolved so your not actually ingesting silver.
Especially over a few week trip i can't see it being a problem.
Is it approved anyone e.g. FDA (or au equiv)
Other option would be a more traditional carbon + uv filter.
stevemc181
I've been using one for ages and haven't changed colour :)
If the filter gets blocked with dirty water, you can turn it around and backflush it. I haven't had to do this on mine and have probably run around 800 litres through it so far. Usually only filling up with tap water though, but I will also put it to use on the CSR next year. I am actually thinking of fitting a second one to filter the water going into my tank, as I currently have it on the outlet side.
Tony_J
That's good to hear that you haven't turned blue!
Are you confident that the filter kills any bacteria/viruses?
I have 2 stainless steel tanks, one for showering, smaller one for drinking. This filter is compact enough and would be an easy solution to fill the tanks with clean water. Because of the way my setup is, I have to use a pump to fill both with water. I was thinking pumping the water through the filter rather than drawing the water through it. That way I only need one.
stevemc181
Yes, I am confident in the filters abilities. Colloidal Silver is a widely used method to clean drinking water and the filter also has a carbon component that helps remove other contaminants such as chlorine and sediments. I think I will also change my plumbing to have it on the fill side of the tank.
Tony_J
Thanks everyone. I went ahead and bought one. A bit more compact than I was expecting (a good thing) and easy to use. All set now.
Thanks again.
Chatty
Thanks again.
Funny you should say that - mine arrived in the post the other day (fantastic service by the way!) and I thought it was a lot bigger than I was expecting...
