Anyone looking for a Mitsibenty
#8
I remember seeing one of these up in Shark Bay, at the end of a fairly rough 2 hour 4WD track. I almost couldn't believe my eyes; you are asking for trouble from the get go with the way they are set up. I wonder what all that weighs empty, let alone loaded. I bet it is over the maximum rear axle weight.
Triton's and Navara's seem to be the most commonly bent vehicles, but I have seen everything from 70 series cruisers to rangers and beyond.
Aaron
#9
Since moving to the city, bent tradie Utes are a common sight, and no wonder with the loads and tow setups.
All Utes improperly loaded will generally suffer eventually. The old tritons faired worst because the rear axle is in an average at best spot. The new triton(my own model) has a strengthened chassis around that area, it’ll still bend if you push it though.
Pack cleverly and lightly and you’ll likely avoid all these problems.
The wreckers across from my work gets bent Utes daily. Rangers and hiluxes are the most common (they are the most bought Utes as well).
hiluxdriver
Found this one parked at Hells Gate on the Savanah Way.
It happened when he hit a washout on the road about 30cm across by 30 cm deep - I know because I smashed it too. Says he hit it at 40kmphr with around 250kg on the ball - all same as me except I didn't break anything. Poor bugger loses all his accessories he can't take off and all the time and money in setting it up how he wants it.
Poor bugger, I think I would be getting some chains, jacks, steel plates, drills, bolts and a welder and botching it up to limp her home
hiluxdriver
He was the nicest bloke. He and his wife had just left Brissy for round Australia trip. Didn't even make it out of the state. Swore he would never buy another Mitsubishi again.
Pay attention @Mitsubishi Australia as this affects you.
I won't buy another one either but for a different reason.
You can hardly blame Bitsamissing, everyone has a choice on what car they buy and everyone knows that modern utes have chassis that are barely capable of dealing with the loads and conditions that manufacturers advertise they are built for. It is well documented all over the web...
I steered well clear of the commercial ute category when choosing the next car for this very reason but it is near impossible to find any car that ticks all the boxes.
I hope he had good insurance cover
#20
I can't say I completely agree with that. Yep, there are lots of bent 'commercial utes' around, but they are also one of the most popular vehicles out there, and there are probably 100 x that have not bent.
I've never seen a chassis bent where it wasn't either overloaded, incorrectly loaded or involved in an accident with a wash out/dune/lump of some sort.
You'll find bent chassis of every make and model ute online if you look hard enough.
If people understand the weight they are putting on their vehicles, keep it legal and don't have any bad mishaps off road they are unlikely to suffer a bent chassis.
That said, I am distinctly aware of the fact that you do start behind the 8 ball with a dual cab, purely because of the overhang on the rear, and that some brands/models are less strong.
Aaron
