any one run 240 volt bar fridge off dual batteries and inverter?
cjch
Hey ppl, just throwing a curly one out there I have a 600 watt / 1200 watt Inverter and a dual battery system in the Hilux and was wondering if any one has run a 240 volt 140 Ltr bar fridge (0.7 amps) while away camping? I have a solar panel as well that I could hook up to the spare battery also.
Cheers Chris
The bar fridge consumes about 150W and if we assume it operates on a
33% duty cycle (that's probably a low estimate) then you'll need 8
(hours) x 150W = 1200Wh each day or 4 x 300W solar panels operating
at full output for the day plus about a 150Ah battery to see you
through the night.
Additionally, because of the way the compressor is mounted in
domestic fridges you'd probably kill the fridge after a few days of
4WDing.
Sorry :(
MH
cjch
Damn but if I were to go somewhere with a powered site I could run it in the back till I got to the powered site right?
cookie64
Agree with Mike, they are not designed to do harsh travel, most Engel / Waeco etc fridges these days will run off both 240vac & 12Vdc
Inverters are not 100% efficient either so you will also lose energy as a result
cheers
darb
inverters are highly ineffecient. That is, they use more power than they deliver ... and not only that, they use a lot of power even if they're idling.
In short its a highly ineffecient way of powering a fridge...
Yes that would be fine. Just ensure the wiring is up to carrying
a load of around 15A.
In reality, if your journey time is less than about five hours the
fridge will remain fairly cold even without power.
MH
If the fridge uses 150 watts then you need a inverter that handle 1500watts , a lot items take 10 times more than there power rating to start up IE: when the compressor kicks in it may use up to 1500watts but once running 150 watts . example I had a ice maker draw stated was 130watts I have a 600 watt inverter, it run but when the compressor kicked in it blew the 20 amp fuse in the inverter
darb
yeah that's a valid point ... AC based fridges tend to spike massively for a few seconds at startup (12v doesnt).
Mate, just get a couple of those freezer block thingoes ... freeze them in your home fridge before you set off ... and whack it in the fridge when you hit the road.
I find even when i add frozen steaks into a warmish waeco (12v) fridge... it drops the temp well below 0c and stays taht way for a day or so ... compressor never even has to kick in.
If you make sure the fridge is already down to temp and its ingredients are , you'l lbe fine...
The bar fridge consumes about 150W and if we assume it operates on a 33% duty cycle (that's probably a low estimate) then you'll need 8
(hours) x 150W = 1200Wh each day or 4 x 300W solar panels operating at full output for the day
No you won't - Harding is an idiot! :)
You'll need a 150W panel operating at full output for 8 hours
of daylight.
MH
cookie64
I have to add, I would not be comfortable having 240Vac in the car whilst travelling, in the event of an accident it could cause some serious issues or even if something rubs through it could certainly liven up the place.
cheers
muc the truck
long time before 12 volt fridges were affordable , dad bought a cheap old kelvinator chest freezer to toss in the trailer . It had more dents than a smash up derby car but every time it was plugged it it worked like a charm. what we did was freeze a 20ltr bucket of ice in it . place our food in there and use it like a esky. placed wet towels on top during the day to keep it cooler. ice lasted a week if we placed a couple of bags of ice loose around the bucket . when we had power we simply had it to a timer so it would not freeze the food. the freezer never stop working it just became an eyesore and was too heavy to move out of the trailer loaded . made an awesome plug in esky but.
If you drive a petrol engined vehicle you already have about 30,000V
in the vehicle at the spark plugs.
240V inverters are not a safety issue because they do not have an
earth reference.
The 240V supply in your house is referenced to earth, ie. the planet.
At your local substation they connect the neutral to earth (iirc it's
bonded to earth at the consumer end too - PME or whatever it's called
in Oz) so in order to get a shock all that needs to happen is for you
to touch the Active conductor and current will flow through your body
to earth and back to the substation, thus a circuit is created and
current will flow and you'll say "Ouch!".
An isolated inverter or generator is *not* bonded to earth so in
order to complete a circuit you must touch both the Active and
Neutral conductors simultaneously - it is *highly* unlikely anyone
would do this by accident.
So providing you're using an isolated inverter, and I think they all
are these days, don't worry about it.
MH
cookie64
earth reference.
MH
Thanks Mike, being a qualified Electrician and Electronics Technician as well I know the ramifications and by the way it is called an MEN link.
Mate please, 30,000 Volts at very low current yes it will bite or cause you an issue if you have a dodgy ticker but it is enclosed in the bonnet or a confined space and the Emergency services know it is there and can manage that, in fact I believe one of the first things they do is disconnect the battery.
If you have a cut cable sitting in the car at 240Vac potential then you have a whole different kettle of fish , not to mention any fluids that may be present.
As a test if it is as safe as you suggest, can you put the 12v in a glass of water and then your finger and then do the same with 240vac then let me know the result
cheers
Oh dear.
Under what circumstances do you think someone would touch the
two poles of a "cut cable"?
And for "fluids" to be an issue they would have to short one pole
to the chassis of the vehicle whilst not doing the same to the other
pole otherwise the fuse would blow.
I have $1000 which says I'm more than happy to hang on to one pole
of my 950W generator or 300W inverter, neither of which is earthed,
and not get a shock if you are prepared to put $1000 up against my
offer? Proceeds to the Melbourne Lost Dogs Home?
MH
peterfermtech
My dad has been running a bar fridge in his campervan off a 1000w pure sine wave inverter. Has just done a 8,000 km trip mainly on sealed roads up North and the only issue was the thermostat in the fridge came loose. He came to me after he had bought the fridge to ask me how to wire it up, however it definitely wasn't my recommendation.
I cut into the thermostat and used it to bypass the power switch on the inverter so that the inverter is only operating and drawing current when the fridge compressor is working. Runs off 3 x 50 AH Deep cycle and 200 W solar panel and vehicle charging. He uses a cheap timer to switch the fridge on and off if he stays at a powered site. Has cost him less than $400.00 all up.
regards
cookie64
Oh dear.
MH
You my friend are an electrical nightmare, there have been many deaths not by people committing suicide by deliberately touching cables but by people accidentally touching cables especially after an event. Hence why all cables and equipment in a commercial situation must be tested to AS3760 to safegaurd against such actions.
Mike don't be such a smart ass all it does is prove your ignorance, touching one pole will quite obviously do nothing providing there is no return path, but you are intimating that it is intrinsically safe to touch the cables as they are not earthed - this is a foolish thing to say and may well end up with a serious injury or death if someone was to take you literally.
Mate I do not know you nor you me but somehow you seem quite willing to take my opinion of "
I have to add, I would not be comfortable having 240Vac in the car whilst travelling, in the event of an accident it could cause some serious issues or even if something rubs through it could certainly liven up the place." and try to show some sort of superiority of electrical prowess to which I am confident that the Technical Regulator would love to have a chat with you and your views
normally I would say cheers but not to someone who I fiond ignorant :mad:
Oh dear, again.
It's not about being earthed it's about the current having a return
path and with a floating system there is none unless both poles
are touched.
Nevertheless, people are still paying me a lot of money to sully their
dreams so I guess I must know something :)
Ah, the old "when you can't win the argument resort to abuse" ploy.
MH
muc the truck
what's the difference to running and charging a decent featured full size lap top to a small fridge from a invertor while driving ? they use about the same power . I see kids using lap tops all the time on invertors . Even my own kids to keep them amused on long trips.
are any fridges double insulted or are they all earthed? I may have answered my own question.
cookie64
Oh dear, again.
are touched.
Oh dear indeed here we go with you dismissing electrical safety and being condenscending to others
QUOTE=Mike_Harding;345302]It's not about being earthed it's about the current having a return path and with a floating system there is none unless both poles
are touched. [/QUOTE]
And that is what I have been saying Mike your constant references to earth are a distraction if you have a instance whereby 2 seperate metal objects that are insulated / isolated from each other and they happen to be electrically connected to one or or other.
You go over a bump and the fridge jumps and severs the cable - Active to fridge body and neutral to the chassis, you then reach in to get a drink leaning across the car and opening the door by the corner, you have now touched the 2 what happens - you get an electric shock - simple.
QUOTE=Mike_Harding;345302]Nevertheless, people are still paying me a lot of money to sully their dreams so I guess I must know something :) [/QUOTE]
I don't think you meant sully, maybe fullfil, and I would trust that your systems that you are either designing, or indeed fitting, are to AS3000 and you are signing off on them - that means you're liable for your design
QUOTE=Mike_Harding;345302]Ah, the old "when you can't win the argument resort to abuse" ploy. MH[/QUOTE]
Abusing you - no, so if people use terms that are direct and not condenscending that means it is abuse, if I wanted to poke fun then I would have a field day about you sullying peoples dreams
sul·ly (sl)
tr.v.sul·lied, sul·ly·ing, sul·lies
1. To mar the cleanness or luster of; soil or stain.
2. To defile; taint.
n. pl.sul·liesArchaic
Something that stains or spots.
As I stated before, I have merely given my opinion and you are the one that was rude by being dismissive of someone elses opinion because it doesn't tally with your thoughts.
