Any one knows what is it?
Komang
Hi Bro guys,
Any one know what this thing are?
Thank you.
Komang
It looks like a heatsink for something that is temperature sensitive.
Yes it thing with heatsink but not sure what for.
Havent yet fisit my friend who has new XLT and if it equip with this thing or not.
Other friend said it the rust controller but I am not sure.
typhoeus
no such thing as a rust controller in a ford!
John U
Where does the wiring go to? I have the same Ute as you. I thought it was something to do with the headlights because of its placement (right behind the headlights).
unless it triggers and srs or ABS fault that needs to be reset by the dealer
Na, if it triggers a fault then disconnect the battery, plug it back in then reconnect the battery and it will go away, the fault will still be logged but it won't stop or put the car into limp mode
Komang
Thanks for the com bro guys.
Will try trace the wire where it goes.
Might give me indication whats the thing.
My guess it will be voltage regulator which always need heatsink like bro dno said.But see where the wire goes.
Long weekend comming might good time for look around the car
Stay safe
