Any ideas 'mechanical gurus"?????
allanmac
On the 2nd last day of the 'holiday from hell', selected 4wdH & a huge clunk clunk noise commenced. Went back into 2wd,& no noise, so that was the end of anymore 4wding. Initial thoughts were uni joints, cv's, front diff or transfer case.....:confused:
Anyway, the paj was 'not well' so went into mechanics for full going over with instructions; "Check everything & replace whatever is needed" So the 'process of elimination' begins with many components replaced, such as driveshafts, uni joints etc, whilst not all completely buggered, but all getting somewhat 'tired'...:( Front diff was fine, so it was now time to 'roadtest'. Noise was still there, so could now only be the transfercase or auto, but transfercase seemed to be the culprit as it only 'clunked' when in 4wd, whether high range, low range centre diffed locked or unlocked etc etc. So off to get pulled apart & whilst it was aprt, get reduction gears installed. The auto was given a thorough going over & had a 'clean bill of health'...:D
So 4 weeks later, all is put back to gether & guess what; the 'clunk' is still there....grrrr.
Transfercase rebuilder is saying it is the auto & auto guys are saying the transfercase. Bottom line, nobody knows !....:rolleyes:
I am no mechanic, but as it only happens in 4wd, I think it must be transfercase ...:confused:
So can any of you mechanical experts shed some light or suggestions as to what might be the problem. I am almost over it all now as after many $$$$ spent, problem is not fixed...:mad:
Alien d2
What are the front hubs like?
Mates 60 Landcruiser had a clunk and click, turned out the front locking hub was dead.
Check where the front axles slide into spline on the hub, I have seen them strip the splines :eek:
allanmac
I believe they checked the hubs when they replaced the cv's Kyle, but I will double check with them tomorrow. It is not a 'click' but a huge 'clunk', if that makes sense.
The 'clunk' is coming from the middle of the car, which leads to me think it is still in the transfercase....:confused:
I might be totally off the mark, but it sounds like it is not 'locking' into 4wd properly, but according to transfercase people, they double checked all the selectors on the 'superselect' system that the pajeros use....:confused:
Alien d2
If the selectors have been checked then it is possible that the problim is internal:(
Might be time to head to a Pajero forum for a search, you've got all night havn't you;)
Let us know what you find please.
Grumpy
I would look towards the tailshaft and universals maybe, only a guess though. maybe worth looking at engine and gearbox mounts aswell.
Big Rig
I would be pulling the front diff centre out and checking to see that there isn't a broken tooth on the crown wheel.
allanmac
Unis all replaced Grumpy.
I might be wrong, but if it was engine and/or gearbox mounts I would think the 'clunk' would be there whether in 2wd or 4wd...:confused:
Split pin
Does it clunk only when you put it into 4 wheel drive? Or when you are in 4 wheel drive? Does it do it only when going forward? Does it clunk when your in reverse?
Just thinking!!!!!!!
Big Rig
Good to see your thinkin Pete.. all good questions.
Davidman
Hi Allan
The front diff has two mounts, a top and bottom. Each mount is really a mount within a mount. I had a noise only when in 4WD ( High or Low, locked or not ) which turned out to be the diff being able to move due to the inner part of the bottom front diff mount being cracked.
Might be worth a look. Hope it is the problem.
allanmac
thanks for all your suggestions guys, am writing them all down....:D
The 'clunk' is there when in 4wd & under load.
In regards to the diff Dave, was told that was all good, but how thorough was the inspection, I do not know???.
Understand what you mean about the extra load in 4wd drive Grumpy, so that is 'on the list' as well.
Keep them coming....;)
allanmac
BTW Dave, welcome to the 'flashing light' saga that shows its face eventually in all pajeros....grrrr
millsy
Could it be the same problem I had about two years ago. It turned out to be a dry ball joint in the middle of the Cardan joint that connects the transfer box to the front drive shaft.
The double Cardan joint, as it is called, consists of two universal joints and a ball and socket between the two units. But the ball and socket, just like your eyball in its socket, is hidden behind the yoke of the cardan joint and can only be seen if one of the uni joints is removed. Apparently a lot of mechanics have never seen it!
Anyhow, here is the thread that I put up when I was asking for help. It all worked out well as you can see. Probably have a look at the first post to compare how I described the symptoms, and then to posts 53 qnd 58 where I described the final answer to the problem and how I fixed it.
Might be of some help with a bit of luck.
http://www.4x4earth.com.au/forum/other-miscellaneous/1705-mq-patrol-binding-clunking-4x4-drive.html
Davidman
The Paj forum are usually pretty helpful. Will try their suggestions for the flashing light over the weekend.
Qute
How's the slip joint on your front prop-shaft?
It is VERY common for the front prop shafts to wear in part time 4WD's as they bounce up and down in the one spot a LOT (in 2WD) and the splines inside the joint get damaged/worn.
Take your front shaft out, select 4WD and go for a short drive. While the shaft is out, check it out... :)
allanmac
Added to the 'list' Qute.....;)
