Another GME vs Icom thread
Lovey
G'day all,
thanks to your advice, I've decided on a GME 4018 antenna for the ute, now to decide what to attach to it.
I've narrowed the choice down to either a GME 3550 (with sound path mic) or an Icom 450, which I believe are fairly similar in specs.
I know the Icom is touted as being a 'commercial grade' radio, however I'd lean more towards a unit with that was easier to use.
I've read that the Icom menu is clunky and less user friendly, also that users may have been 'locked out' of the unit whilst on the road, however I don't know how true this is.
I've searched for a direct comparison, to no avail as I think the 3550 is only new to the market.
Is the GME 'easier' to use than the Icom?
Is the 'clunkyness' of the Icom menu something that has been talked up, or is it actually harder to use than the GME, bearing in mind that I'm a newbie with UHF's, and it would only get occasional usage?
Thanks for looking.
billolga
I have an old GME 40 ch & a new Icom 80 ch. I don't know what the new GME's are like but I love my old GME, particularly the in front speaker.
peterfermtech
It's like anything with buttons. The one you've been using is the easiest. I've had a GME an uniden and now I have an Icom. I've never used any of them enough to remember how to use them properly. I like the icom because the speaker is in the handpiece and I can hear it.
regards
cookie64
I have the Icom and can't fault it, it is actually easier than it's predecessor (440), it is a commercial grade radio and the 440 was still going strong but upgraded to the 80 due to everyone else in the group having the 80 so some of the conversations were soft on the reception.
I initially chose the Icom as GME had some issues with the power supplies in their units but that should be long fixed by now.
I would suggest going to a good communications shop such as Electric Bug or Transceiver Services here in Adelaide and have a look & listen to what suits you and what your comfortable with, like anything once you use something you get comfortable with it
cheers
Hi Mate
Keep it simple, GME radios are good at that ,you wont use most of the features anyway...Scan,Memory,Open Scan and thats about it,i like an external squelch button and a forward facing speaker or external..
rogerazz
I have a GME and it is fitted under the dash more so passenger side of middle. Being noisy on the road, track, sand dune, partial deafness, whatever, I do have trouble hearing the speaker on the front of it while driving. Maybe I should look at extension speaker or siting the unit close to my head.:rolleyes:.
Then my Missus would not have to keep telling me what the message is coming over and me keep saying, what did he say????:eek:
mac_man_luke
both will do
I have the Icom 440 (previous version) and the menus are a little odd but i think i used them once to set it up and have never touched them since. Everything else is easy as and i love it.
People tend to forget, they say i'm transmitting fine. Well how do you really know this, have you bothered to swap vehicles for awhile to see if your radio is working properly and transmission is clear , a simple radio check doesn't tell you much unless you ask where the reciever is and a 1-4 quality of call...
From Frankston on a repeater I can chat to guys at Phillip Island, from my Garage I can talk to guys in Cranbourne without a repeater and it's over 10kms away. I'm happy with that..
Spooner
I got the GME TX3550S with Soundpath with all controls on mic fitted just over a month ago .
I couldn't be happier with its performance .
And I'm a half deaf trucker truck driver by trade :)
Lovey
Thanks everyone for taking the time to provide feedback and advice. I still haven't made a decision and I'm still researching.
Thanks again.
ziggybyrne
I've had uniden (which was shite) GME and Icom uhf's. I like the simplicity of the GME and find them very intuitive to use. What I don't like about them is that the curly cords literally disintegrate after a few years - which has happened on the $150 controller mic for my tx3820. While I like Aussie made stuff the Japanese made Icoms are in a league of their own. The Icom 400 pro is very solid(including the microphone which is original). It looks and performs like the day I bought it in around 2006. The audio is loud and clear even in noisy environments. But they take some getting used to with regards to the menu system. Also the user manual is in "janglish". Pretty tough to get your head around at first. I've had a simoco srm9000 and it was very high quality, and while it has more custom features than you can poke a stick at, I've gone back to the Icom as I like it better as a CB for general use(especially as the emergency services move to digital etc). I leave the squelch set on 50 for the Icom.
Cheers ziggybyrne
Lovey
Thanks for everyone's input and suggestions. I ended up going with the GME 3550 and 4018K1 bundle, just have to get it installed now.
Thanks again all.
Thanks again all.
If you have the time there easy to install, you can buy the cable with connections already fitted either end from Jaycar..
Lovey
The bundle came with everything to install it and ordinarily I would install myself, but I've just had a bit of eye surgery and I can't go near anything dusty or dirty for the next month :(. I can't have it sitting on the shelf looking at me for a month, so I'll get the local auto sparky to install it for me.
barnsey062
looking at getting this package....thoughts ?
$259 including postage
http://www.ebay.com.au/itm/GME-GENU...994922bec02034fb856b2f&pid=100505&rk=1&rkt=1&
Features
Power 5 watt
Transmit and receive 477MHz (UHF CB)
Selectable duplex
80 channels - 77 including telemetry (receive only) - 3 reserved for future use.
Scanning and memory
Open/Group and Network Scan
Memory channel quick select
Selectable priority channel
Active channel transmit in scan
Privacy CTCSS
DCS and Voice Inversion Scrambler
User controls and interface Rotary volume and channel controls
Speaker microphone with push- to-talk, channel up/down, priority and scan buttons
Large LCD screen
