Amplifier for external UHF speaker?
Tony_J
Hi, my UHF uses a GME external speaker but I like to drive with the window down. I have the volume up as high as it can go but I cant comfortably hear the speaker unless I put my window up.
I'm sure I could get a cheap 12v mono amplifier (in line between the UHF and external speaker) to boost the speaker volume but am not sure what to search for. My home town does not have a store that sells this kind of equipment so I will have to purchase 'on line'.
Has anyone had an experience with this stuff or could tell me what I need?
The speaker is between the seats about shoulder height but is just not loud enough with the car, road and wind noise.
TIA
Marck
Call a jaycar and ask them and then order it online from their online store. If you can solder you will probably get a kit you can throw together as an option also. Just make sure it will accept the high power output from your UHF and not just a line level input or it will just distort.
vk1dx
Our VMS box has Aux AF and Aux Video inputs. I can plug the UHF speaker output into it and raise the roof if I wish.
What bout your car stereo/entertainment unit. Does it have a similar input?
Phil
Example (not our box). See the AUX socket top left.
GUnka
I would be very careful plugging an amplified signal such as the UHF speaker output into an "aux in", these circuits are not really designed to handle wattage and really designed to take a line level signal as Marck has made similar mention above. You can generally get away with it provided you turn the UHF volume way down (lower wattage) and use the radio/head unit only to increase volume. Just avoid using the UHF volume or you may risk doing damage to your head unit.
vk1dx
I am so used to doing it in the past, that I forgot that bit. Thanks Gav.
In the days of analogue radios, we used to be able to run a wire from earth and the "top" of the volume control and feed this low level output through a suitable cap and then out through the Ext speaker socket and then to the car radio. But that was a while back and I don't know the radio nor the circuit diagram. Maybe a local ham or radio shop could help.
Phil
Gavo
Also I'm yet to see a car stereo that play's aux signal at same time as your FM or CD for example.
I had same issue with my truck. I ended up moving forward extension speaker to next to my head on cargo barrier.
I've heard of people mounting one in the centre of their head rest as well.
But as mentioned, I believe jaycar do sell a simple amplifier for mono. But the voltage is likely to be lower than 12v.
Wang
I have mine in the headrest and really like it.
Kids can have their music on and i can still hear the chatter on the UHF and they cant hear the language if its on CH40.
GUnka
No probs Phil, I like the idea of running it through a radio. Only prob is you have to have it switched to the aux in the whole time meaning you cant listen to the stereo at the same time. Pity you couldn't get something that's blue tooth that cuts radio out when the UHF receives similar to having a phone tethered to a head unit.
GUnka
Beat me to it Gavo, us Gav's must really be on the same wave length :eek: lol
vk1dx
My imagination told me that you wouldn't be listening to much of the radio with all the wind noise so it wasn't a problem.
Maybe the Jaycar solution would be the best.
Phil
Try this one: http://www.jaycar.com.au/Kits,-Scie...e-Project---High-Power-12V-Amplifier/p/KJ8076
GUnka
It wasn't me who wanted it. For that much wind noise to drown out the UHF I would imagine the OP must be driving at highway speeds. Personally I don't tend to drive window down at high speed purely because of the wind noise and buffeting. I have small wind deflectors around the windows so I can drive with the window down a bit and they do cut down a fair amount of windnoise. I run a GME ext speaker with my UHF mounted just in front of the stubby stick due to where I have mounted the UHF unit and the inbuilt speaker is enclosed. It does the job but isn't heaps loud and still run the UHF at full volume. Out on the tracks wind noise not exactly an issue due to the speed traveling and or dust so would have the window up most of the way anyway.
vk1dx
Gav This is not meant to be a joke or giving you a hard time mate, but why full volume with e CB? You either have a radio with a weak amp, a speaker with the wrong input impedance (unlikely with both GME) or just want everyone else in the convoy to hear. Our GME is mounted on the left hand side of the center console near the passengers legs with the speaker on the console side and, one could say, hidden. We have never had it louder than half way. No external speaker either. Even with the window down we can hear it okay. It's even at half volume in the photo below.
Anyway I will leave it with Tony and hope that he finds a solution.
Catchya
Phil
GUnka
Industrial deafness might be contributing a bit. 25+ years of banging hammers, big grinders, loud machinery can have an effect. :(
Tony_J
vk1dx, that looks like what I need but it comes as a kit without instructions and soldering that type of gear is out of my capabilities.
My radio is a remote head GME with a GME UHF extention speaker. Even on full volume it is very quiet. OK when crawling slowly thru the bush, but useless over 60kph with window down. Mounting the speaker closer to my head is not an option. My wife can't hear it either. I'll keep looking for an assembled amp.
Gavo
Or could be like me, driving a tin box with a v8??
Hylux
Yep have the same setup. The output of the gme is pathetic. I have an old 40w amp in the shed with high power input and might give it a go.
