Alpine diesel
phs
So is it a must if your staying over night in the snow ?
And if you have 2 tanks and 1 has not got alpine diesel in it that you are using while there and the other is normal diesel and just being used as storage for the way home ( not alpine area ) will it be fine ?
peterfermtech
Yes unless its not likely for the temp to drop below -3. Better to be safe.
As long as you are sure the tank will be warm by the time you use it. You can buy an additive where you buy your alpine diesel which you can add to your reserve tank or your main. I bought it in bulk (5litre) from here.http://www.trubluoil.com.au/index.php/automotive/admenu as a couple of times they did not have the additive available.
regards
Any diesel you buy in the snow regions NSW / Vic / probably Tas will be Alpine grade, so just arrive with at least the one tank near empty, drive up and switch over when say 5km out form parking, you will be fine.
Personally I would just have 2nd tank low and top both off as much as possible, allow tank you have high % of Alpine mix in to flow through the system well.
I would be surprised if all stations within say 100km of any of these regions don't have suitable diesel from their pumps.
peterfermtech
Not always the case. You need to check and it is usually just the sub alpine towns. For example the BP at Glenrowan where a lot of people stop on the way to Falls/Hotham does not have alpine mix and nor does the Caltex at Myrtleford. If you are going through late at night or on a Sunday late-ish you can get caught out. Also if you want a full or near full tank of Alpine mix you need to manage your fuel levels before you leave home so your tank is near empty before filling.
regards
Gavo
It's not worth the hassle of not getting it.
Back when I worked at 1600 meters above sea level, I used to see diesels with waxed up fuel lines all the time.
Essentially the fuel lines get waxy, and only way to fix is warm water all over the lines. Tough to get to the ones along chassis to.
Do yourself a favour an ensure your coolant is correct. I've seen plastic radiator tanks split from frozen coolant, and welsh plugs pop out.
I think most radiator shops can take a sample and check freezing point of coolant.
Apparently it is a heating oil that is added to make Highland (~ 10%) or Alpine Diesel (20 - 25%).
Best to ask for sure, ring a couple at towns you think you'll be filling at.
In the main, from say April - October most local servos in these regions have the right stuff . . . or just as a back up take some Risolene . . . it won't do any harm if you use it another time to treat the fuel.
For sure, coolant full check (even replace is dodgy), ensure cooling system is A1.
Ziggy
Additive is a dead easy solution. But a town like Mt Beauty on the way to Falls Ck will swap over to Alpine as a matter of course in winter.
To take Myrtleford again, last year the Caltex on the south side of town had one bowser of Alpine and the rest were for the standard brew.
One morning at Falls last year it got town to -9 and the RACV guy was pretty busy!
Have your battery checked before you go too.
Chatty
And don't forget to give yourself enough running on the full tank of Alpine mix to ensure that the supply AND return lines from and to the tank are flushed through so they don't wax up in the cold. Remember common rail engines run a fuel loop to keep the injectors cooled. Shouldn't take long - I would have thought five minutes running or so. If you have dual tanks I would run the transfer pump for a few minutes as well.
  • Like
Reactions: phs
phs
yeah coolant is ok rated to -18c
I called mansfield BP all there diesel is alpine diesel currently.
Only drama is both my tanks are nearly full of BP ultimate .
Hoping to siphon the lesser tank into the other and fill a jerry or 2 up
Flushing the lines won't be an issue on my 79 they move a fair amount of fuel though the lines should be right in about 30 seconds after switching
phs
Well went to buy a jiggle siphon hose and ended up buying flashlube winter forumla additive, the guy convinced me it was the better option
I also called the customer service line the tech guy said it is good to go on any type of motor including CRD
I asked him if it was the same as alpine diesel he replied " well it depends what they use ? We supply this to alpine diesel storage tanks in mountian areas "
Any thoughts ?
In general alpine diesel is out of a depot somewhere, trucked to outlets that need to stock it in winter.
Fuel outlets needing / wanting such grades for winter would just get it is, ore than using an additive.
Maybe some outlets use it to stabilise fuel as well, with condensation issues etc.
I would either just use the Flashlube (if it's the one above), or just confirm before fuelling up that you are getting alpine fuel . . . if they advise yes, then you might be better not to add anything further.
The Flashlube can be kept for another trip sometime I guess.
Suppose it is this one they are talking about http://www.flashlube.com/en/products/flashlube-winter-fuel-formula.html
phs
^ yes that's the one
My options are
1
add alpine diesel from BP mansfield to approx 1/4 - 1/2 a tank of BP ultimate and use that
2
add flash lube to existing fuel
3
Siphon one of the tanks and fill with alpine diesel in manfield
peterfermtech
The simplest option for me when I go to Hotham is to use the additive. I generally have to use some additive for the fuel already in the tank anyhow so I can just fill up when I'm ready and don't have to worry about paying "snow town" :eek:prices or worry if the fuel really is alpine mix. :oops: The tru blu additive(artic defense) that I use cost about $80.00 for 5 litres and mixes at 1000:1 so 1.6 c a litre or a $1:00 per tank so why would you risk it otherwise.
regards
Paddler Ed
Also don't forget to wait for the glowplug light to go out, and if an older engine, even flick on a couple of times in quick succession, waiting for the light to go off each time. That can help to start it.
Just don't do what they used to in the northern UK in the early 1980's/late 1970's... light a fire under the diesel tank on the truck to clear the waxed fuel lines.... eventually it would all go up in smoke, especially as a lot had GRP cabs at that time...
Ed
Pommie who escaped the cold... and is somewhere it's forecast to be minus 5 tonight... and no snow...
