Airtec Snorkel on 120 D4D Prado
Big Rig
I just had an experience with TJM today so a small word of warning if anyone intends fitting an Airtec TJM Snorkel.
I looked at both the Safari and the Airtec and preferred the look of the the airtec. I proceeded to have this fitted by TJM. After I picked up the vehicle I decided to give the engine bay a wash only to find that the snorkel was not clamped to the air cleaner box. I went back to TJM today to find that this part of the install was factory Toyota and had nothing to do with TJM.
When I showed the guy at TJM that there is absolutely NO seal what so ever, the first water crossing you come to water would just suck right in there. He did understand what I was showing him but continued to quote that he fitted it as per the instructions and that it was up to me to do something about it.
I met up with a customer over the road at ARB who had a Prado with an Airtec snorkel so I asked to look at his install. Low and behold he had the same issue but didn't know it and I found he was off to the Cape like me in 7 weeks time.
Every one be warned, check this out because you will damage your engine. I took the whole air cleaner box out, sealed the join with silicone and put a large aircraft grade cable tie around the join to fasten it.
Split pin
I had the same problem with my Nissan Patrol but on the factory fitted one. Suffice to say I told the service manager that if I went through a water crossing and the motor filled with water that his department would be held accountable he basically laughed at me.
So I did the same as you.
When Brunswick installed the chevy they ensured that the air intake was sealed all the way from the top of the snorkal to the inlet manifold.
Big Rig
It pretty horrifying to see the oversight and even more horrifying to find that a well known and professional franchise like TJM would just snub this issue off. These are the guys that newbys rely on for sound advice when purchasing products... and they really don't give a toss. They got their money, fitted as per the airtec instructions so lets just was our hands of it. I too told them that they would have been the first port of call if my engine stuffed up.
4WDN
Not good at all.
'aircraft grade cable tie" you need to keep some heavy rated gear for them Prados.
Juggs
still waiting for my tonearm cover to come in 5 weeks after ordering one from a tjm store
gave up 2 weeks ago it gets fitted tomorrow by someone else
croozza
over the past few years TJM have build up a reputation of not caring, Big Rig I would check the holes that they drilled for the snorkel as they would not have put anti rust on the exposed metal and a year or two you will get rust in your guard.
bmurray2250
I installed my Safari snorkel and used penatrol on all the exposed metal. It will seal the metal and stop rusting. I noticed on some installations the mount area on the pillar section is moving. I avoided the plastic mounts and sealed the screws in the penatrol and silicone sealant. The guys that cut the holes in my guard did a fast job and did a poor cleaning of the area and sealing the bare metal, hence I re-cleaned everything up
Crisp image
OK so Mr TJM said it was a toyota issue. I think that if he knew about this issue then he should have said something about it to you. Now I do not think he should have fixed it for free as it was not really part of the install however I am sure that a small charge (and consent from the customer) to correct this issue would have not been out of the question. I comes down to good service and advice. Then you tell your mates how good they are and then repeat buisness starts. Word of mouth is the best advertising you can get (also the cheepest) but you have to build the reputation up but that reputation can be destroyed in seconds.
My thoughts.
Regards
Crisp Image
Big Rig
Well i'm apauled at the fact that this issue wasn't corrected at the time of the fitting. I don't really care whether the fitter followed thedirections for fitting or not. You just don't let a car go out with a newly fitted snorkel knowing tyhat it is going to suck a gutfull of water and ruin the motor. Why do we fit snorkels???? To keep the bloody water out. You don't have to be a rocket scientist to see that there is an issue. This should have been rectified and I DO blame TJM. After all, they claim to be the experts, this is why they want us to console in them!
This whole issue is no different to taking your car to a mechanic for a service. There may well be particular items you replace at a particular interval BUT if the item is checked and found to be defective you contact the custom and reccoment it be replaced. You don't just say ah well it doesn't get done this time so we'll wait.
Gday ,Im not one to bag out another business or the like as this is un professional and un ethical ,but I would just like to give my point of view .
We try our best to do the rite thing by all customers no matter if its a small job or big job , you can not please 100 % of customers no matter how hard you try - but we do try .
if I ever had a staff member talk to someone or treat a customer like that they would last 5 mins .Or if I ever did a staff member would kick my butt .
Going by fitting instructions for a safari snorkel part no ss12ohf to suit an 05 hilux with 3.0 lt D4D TDI motor step 13 page 3 in big black letters
( NB it is the installers responsibility to ensure all connections are water tight )
A method we use to ensure all is good after fitting a snorkel is remove the top air ram ,with the motor running place ya hand over the top of the snorkel and see if the air inlet trunking sucks in -by doing this if there is an air leak some where you will also hear it and be able to rectify it .
Hope this dosent sound like Im pissing in my own pockert or offend any one but I do have the best staff we do try our best and if any one from TJM or that particular store reads this take note simple customer service and having the responsability to rectify a problem / customer gripe goes a long way
just a point of view and some maybe usefull info for others also
croozza
Well said, one of my mates who owns a 4wd accessory shop up here in Brissy does exactly the same thing, it is up to the installer to ensure that all of the connections are water tight, otherwise it can come back and bite you in the ass, big time.
Crisp image
Maybe the airtec snorkle instructions do not say that it is the installers responsibility so they think they can get away with that.
I like the look of the airtec but somehow I am now lening towards the safari.
MMMMMM.
Regards
Crisp Image
PS I think it is OK to blow your own horn if you can back it up with the actions.
bmurray2250
Safari had everything in the box and no issues installing by the instruction. The AirTec looks nice but I liked the idea of spinning the intake around on dusty conditions. You can add a filter sock to help drop the dust getting to the air filter
oznog05
How piss poor is that, as mentioned, whats the point of fitting one if it's not going to work. The TJM fitters should of made sure it work's period.
Drongo41
Absolutely incredible.I must thank you all as I am at this time looking to put a snorkel on my challenger. Now aware of many things to check. Johnno
Nicho
i had my snorkle fitted by TJM in Dandenong worked good when i looked there was a heap of Silicone around the Snorkle to airbox join .that much silicone in a bathtub would make it fall through the floor .so i now no longer trust any of the big 4x4 companys i want a guy who knows what he's doing and is commited to service to the customer .I think GOR might be that company.
Nicho
Big Rig
Brian, my filter sock system I use on the airtech is by far better than the one that can be used on the Safari. I use a finer filter which is an actual sock that fits inside the snorkel body. It was great up the Cape.
