Now that is a great idea , I've got over 80% of that sitting in my shed at the moment
, t-pieces elbow, joiners, tubing, air valves, festo air gauges, nitto fittings, air controllers & bleed valves , just need a relief valve and those clip on connectors for the tyres
You could set it up to air up/air down as a set of four, then shut a valve or two and air up front / rear to different pressures for road use
And know that both or all are at the same or required pressures
Give me a little job to do on rainy rain soon.
WooHoo !!! - thanks Les
, was wondering what i could do with all pneumatic stuff I picked up as an auction for $20
For those interested - Kempe Supply Group -
www.kempe.com.au have the fittings and hose, and should be able to get in a lot of the other bits for you.
(If you have an industrial area near you likely Kempe is in there - they are Australia wide )
