Air compressors for changing wheels recommendations
su888
Folks,
I've been looking into buying an air compressor for the garage to change wheels on my car. From my research there are basically two types belt and direct drive type, with belt driven being the pick of the two due to noise (lack of), and also its ability to fill up the storage tank quickly.
Can anyone provide some first hand experience with purchasing an air compressor and recommendations on what i should be looking at or avoiding. Ive seen direct drive types for $150 all the way up to peerless direct drives to $1000+.
I'm looking for something reasonable built, for primarily changing wheels. (Won't be spraying or nail guns or anything like that anytime soon).
David
mac_man_luke
If your just changing wheels a super cheap special will do (although noisy)
Otherwise a entry level belt drive will be more pleasant to use.
Swampy83
Hi David
I have a tradesmaster12 belt drive fills up quick relatively quiet. Had it 10 years now and never missed a beat and its on nearly every day.
I have few mates with different types and all of them want mine.
Cheapies hmmmmmm I wouldnt waste time on them, I had a cheap one to start with brand new with a rattle gun and it wouldn't undo shit with out a struggle and had to fill up every 2 seconds, so back in the box it went.
Go the decent one first and that way you will be able to use it for other stuff as well, which believe me you will find heaps to do with them
Fox
PJR NSW
Banned
Initially installed under the bonnet, we put the ARB CKMA12 in a void beside a drawer in the back of the car. (needed room for a third battery under the bonnet). Cost unknown as was a package deal. A bulkhead outlet was installed at the rear of the drawer system by Pirtek for easy access. Very neat and tidy and so easy to get at.
The ARB blurb states: – High Output On-BoardPermanently mounted, this water, dust, heat and shock resistant compressor can be used to activate Air Lockers and will perform a number of other functions with an optional tyre inflation kit sold separately.
I am not connected with ARB or Pirtek in any way, other than being a satisfied customer.
345 chippy
as a carpenter,in the trailer i run a 12cfm beltdrive ingersolrand. ive had it for over 20yrs and NEVER had a drama.
for the shed i run a 8-10cfm(which most cheeper compressors seem 2 b) belt drive colt(bit better than the bunnings/supercheep stuf), these dont have the balls 2 undo wheel nuts that have been dun up bY a tyre joint.
its all about the cfm with compressors, tank size doesn't matter, the smaller the tank the more it will run.(well does mater when using a nail gun/spraypainting).
not 2 much between belt drive or direct(direct just start up easyer).
if u say its for doing ya wheels occasionaly a small 1(30-40lt tank) will b fine with a torque wrench.
if u r talking about running 2 sets of tyres(road and offroad)and u intend 2 change them often, i would not recomend using a compressor as u will destroy ur wheel studs.
hope this helps
cheers 345 chippy
su888
Thanks all for your responses.
Chippy - yeh its basically to run two sets on tyres (every 2nd month or so). Why don't you recommend running a compressor to change tyres? What i've been taught is you can use the compressor to undo them, but when it comes to tightening them do them with the torque gun just to get them on. But hand tighten - is this correct? How does the torque gun damage the wheel stud?
345 chippy
i was told many years ago when i first decided 2 run 2 sets of rims and tyres that if i keep changing them over on a regular basis(with a gun) this will fatigue the wheel studs, weeken the steel and snap off.
just some thing i have never used on my wheels,and i have never had an isue.every second change i use a loctite product called nickel anti-seize and brush a small amount onto every wheel stud.
hope this helps
cheers chippy
mac_man_luke
as long as you do the final tighten by hand you should be ok, just dont want to overtighten them like is so easy to do with a rattle gun.
m6sports
I'm a fan of the cheap air compressors, they arn't the most powerful but do a great job for around the house. We use one at work everyday it gets turned on at 8am and turned off at 5pm it has the tank drained out every month or two and gets replaced every 2 or 3 years
I've never had one die on me but they become noisier so we just replace them. If it was for spray painting I wouldn't bother but for small equipment like a rattle gun they do great
Rocket55
I run 2 sets of tyres and change them usualy every 2 weeks. I also have an air compressor (cheapie, been faultless for about 9 years now) with an Atlas Copco rattle gun, a 18V Makita rattle gun and the good ol cross brace. Generally I couldn't be stuffed turning on the compressor letting it build up, uncoiling the airhose etc. The 18V rattle gun tends to rattle the chrome caps off the wheel nuts, so generally I end up using the good ol cross brace (about $10 and Supercrap). Support the brace and give it a spin and the nuts run on/off in no time. Sometimes when I'm lazy I'll run them on/off with the cordless gun.
What ever the method I always start the nuts by hand and complete the final tension by hand, and with a quick spin of the cross brace there's no real need for fancy gadgets. The cross brace also acts as a great tool to place under the tyre and lever it up and onto the studs, saves trying to dead lift a bloody 4wd wheel and tyre.
vicmikl
Don't want to teach anyone to suck eggs but torque your wheel nuts, over tightening will cause fatigue on the stud and once one goes the others will follow surprisingly quickly.
I use an 18 volt Makita rattle gun with torque straws and a final check with a torque wrench.
Michael
choochie
Not the answer you're after but I'd just stick with a wheel brace and spend the money on other fruit for your fourby. If anything then a torque drill (I.e. Milwaukee as mentioned before)
[Tapatalk2 on Nexus7]
Grey Ghost
Like rocket said, do it by hand, just as easy and a sh!t load safer in the long run....
