Air compressor
mikehzz
Does anyone know of any other brand of decent air compressor that cuts out automatically like the arb ones do? I'm sick of blowing hoses because the compressor keeps going when not connected to the tyre valve. If I'm too slow between tyres having a chat, I've had the hose blow because the compressor just keeps pumping. The arb ones are good because they cut out at a reasonable pressure and start again automatically when needed. They cost accordingly though.
Mike you can buy a pressure cutoff switch on eBay for about $30 if you wanted to hook it up to your existing compressor
abw
I just have a pressure relief valve, which bypasses the air to atmosphere when the air pressure reaches 120psi. It tees off the outlet on the compressor. I use one of those ARB trigger inflators. I've had this setup for a year.
I'm sure most of those pressure release valves in air tank kits just cut the power at a certain level, come in at certain level of drop.
Plan setting that up on board with a small air tank and existing compressor.
If you can build into the airline, they should work the same . . .
Or maybe look for a tank and kit, a good time to get that extra flexibility.
Your tank will be a bit pumped by the time you walk to next wheel etc, and using a proper tyre inflation gauge, so easy to just air up to right levels (unlike the compressor gauges, where you need to check and adjust with a tyre gauge afterwards).
GUnka
I set up an onboard air using a 6 litre hotdog type alloy tank mounted at the very top of the cargo barrier using a thumper type compressor. Mine was a Dr Air proflow. These were the precurser to all the copy cat cheapies you see getting around these days. It's rated at 150 l/m and 150 psi max pressure. Based on this I purchased a 110-135 PSI pressure switch. I also installed a mini reg to ajust outlet pressure. All hooked up and running, adjust outlet pressure to 90 PSI on the reg. Waited and waited, comp never switched off. Cranked the reg right up. So called 150 PSI rated compressor barely got to 120 PSI (dead headed) :mad:. Had to order another press. switch next range down which is only 80-100 PSI (same as ARB use on their setups) Quite annoyed as have lost a fair bit of stored capacity just because the compressor was unable to get anywhere near it's so called rated max pressure.
Am now looking at teeing in parallel one of these bad boys http://www.ebay.com.au/itm/BOSS-PX0...low-Rate-/251929294172?_trksid=p2054897.l4275 and putting the 110-135 PSI pressure switch back in and atleast getting higher pressure storage but also around 300 l/m, alot better for blowing out filters and can run air tools.
Gunka I was going to set up one of those Boss units but decided against it and went the ARB twin unit instead
The Boss units are quite big and bulky and by the time you add the pressure switches hoses and fittings the price is not much different to the big ARB unit plus the ARB one airs up quicker than the Boss as well
The other thing I like about the ARB twin which I didn't realise until I was was fitting it up is that both compressor units are individually wired and the compressor will work fine with one pump down.So if a pump shites itself you still have the other pump working
They are 100% duty cycle as well
dirvine
I have a 10 litre tank mounted undet the car. I have a 450C Viair compressor, 100% duty cycle. The cut out switch is at 135psi and on at 90psi. That compressor runs to that pressure (ie fills the tank to that pressure) in about 90 seconds. I use it for rattle gun, tyre pump, and many air tools. Like most people I bought the flebay cheapie and it was just a wste of money. Viair are rated and have been tested. Only a single cylinder but it has not let me down for over 3 years! They have a web site for their products.
The Bushranger Maxair unit is a Viair pump
Very reliable unit and as quick as the cheapie supposedly high flow eBay ones
GUnka
I looked at Viair. No doubt they are a quality product but their air flow rates are very low. Even with 2 of their biggest 480C's you would only get just over 100 lpm and cost $$$$$$$. Try blowing out a few air filters and see how long it takes as this is where you really need flow and for me airing up tyres and blowing out filters would be what it is used for 99% of the time. Most air tools require a reg pressure of around 90-100 psi, and still require reasonable flow rates to do the job especially things like a rattle gun that will only perform and reach designed torque rating when at continuous 90 psi and around 100 lpm. You don't require that sort of pressure for airing up or blowing out filters etc, you can do that at 40 psi so long as you have high flows. Having a tank buffers that requirement and the bigger the better but will still drop pretty damn quick if you dont have the air flow.
To each their own, is just the way I look at it.
dirvine
All i can say is that stated flow rates are just that, and people soon find out the truth. Everytime I go out with 4WD club, my car is always aired up at the end of the day before anybody else. usually cars beside me pinch my air gun and do the tyres on either side of me. I have seen Thumpers, ARB etc etc and believe me mine is far quicker than any of them. As for the rattle gun etc, I really only use it for changing my wheels, so by the time I undo 6 nuts, pull the wheel off, put the new one on and start the nuts on the thread, the compessor has already stopped as it has reached max pressure. I would have liked a bigger tank but that was the biggest i could get to fit in the space. I didnt get it to use in a workshop, just to make things easier in the bush!
GUnka
Having a 10 litre tank charged to 150 PSI at the start in comparison to those using just a straight compressor is not a fair comparison when it comes to airing up regardless of compressor brand. It would be interesting to see how it would go against the others straight out the compressor. The 450C as you say are rated and tested at 0 psi they put out 47 lpm, 20 psi=39 lpm, 40 psi=37 lpm. Considering you would be airing up from around 20 up to 40 psi lets just say an average of 38 lpm. I find it hard to believe that something rated at 150 lpm free air like the the thumper type would only be really putting out less than a 1/3 of what it says it should even if it really isn't putting out the full 150. I know for a fact pefor i set mine up with a tank I was usually done with all 4 tyres while other with ARB had only done 2-3.
GUnka
Tyre size also has a fair bit to do with how long it takes to air up too. For instance, a 265/70/17 takes quite a bit less air than say a 285/75/16 also. If one wants to compare it needs to be apples with apples and not apples with bananas.
dirvine
Gav I agree it depends on tyre size etc. And yes the tank makes a difference. One of the reasons I put on one permanently on my vehicle However, as I said. things advertised at 150 litres are not backed by any reliable specs. That's what makes direct comparisons hard to evaluate. But clearly many quoted at (or advertised as such) do not cut the mustard. I wonder if you could have them up for false advertising? I have not seen any specs on a Thumper so cannot compare. And various tests of compressors by magazines etc do not have a Viair compressor in the comparo's. Trouble is apples cannot be compared with apples because no one has done one with all types. However having said all that, if I had the money, I would have put on an endless air unit. They are rated and just blow everything else away (no pun intended)
GUnka
I have to agree re an endless air unit. I would have gone one myself had it not been for the fact that for just the bracket to fit a CRD Patrol they want around $500 which is more than the compressor and is bloody ridiculous and bordering on criminal for a few bits of welded metal and a couple of bolts!!!
oldlux
I notice in the States Co2 tanks are popular for tyre inflation but I have not seen any here, does anyone know of them being used in Oz? Compressor volume is usually measures on the suction side (inlet) with outlet open to atmosphere and can change drastically between individual units when working against a back pressure it is the same as having two engines of the same swept volume and expecting them to have the same power, torque characteristics.
chris_stoffa
There are guys who have built their own endless air using an reco'd aircon compressor and made their own brackets ( or had them cut for them )
Given that for most simple patterns the set up fee is $120-150 and the part itself $10 worth of steel if you can work out what you need a home made endless air might be very viable at those prices.
akin
@ GUnka I am running one of the BOSS PX07 and might not be fastest (I dont use a tank) but man they just keep on pumping have done 16 tyres straight after each other with it.
No cut outs etc just kept pumping away. I want ti install a tank and use pressure switches etc and like a lot of things its on the list.
GUnka
I don't have an issue with the compressor side of things and would be happy to pay the price asked for one. The idea that like you say, $10 worth of steel plate can be marked up to the point of costing more than a precision piece of machinery such as an aircon compressor converted to just pump air is what I find borders on offensive. It is probably why you can not find a picture of one of their brackets anywhere because they know anyone with half a brain could copy it quite easily. If anyone with a CRD Patrol has an endless air set up a couple of pics of the bracket and it's install would be highly appreciated. :)
GUnka
Cool, thanks for the info. I can show you my set up on the August BT run if you like although I have mounted the comp in the rear right quarter cavity so you cant see that bit...lol.
akin
Mine is located under the wings of my drawers and would be keen to see the tank setup for sure.
