Air Bags suspension Yes or No
Piggins
Okay guys,
I need some help please. I have a 2009 hilux with a 2 inch lift with medium duty rear leafs.. I am setting it up for traveling mainly. My problem is when i load it up to go away it starts to run nose up and that drives me insane. So i was thinking of putting a set of Air Bags in the rear to help out and hold it level. I was thinking air bags because i don't always carry a load unless i am traveling. Or would you say add a leaf? Could you please try an give reasons for your answers if you have any.
Cheers Piggins
oncedisturbed
have personally not used them so I can not comment. from what I have read, going either way has been mixed reviews.
there was a fairly lenghty thread in the suspension section of at 4wda ahile back, will see if I can track it down for you
35Henry
I would not recommend using air bags in your situation. You have already noticed that the back goes down under load and the front comes up. That will happen with any car with too much weight in the rear because the chassis pivots around the rear axle. This link Land Rover Discovery Destroys Tow Truck (short) - YouTube shows an extreme example of what happens when situations like that are taken to the limit. This won't happen to you because the weight you curently have on the car is not enough to do it but it is enough to make you realise you can't drive it like that so you are trying to do something about it. If you lift it up with air bags though, the whole situation changes and there is a very real chance of the chassis bending. Enter words like "dual cab chassis bending " into Google and you will find enough reading on bent chassis to keep you going for hours.
The air bags have created a new load bearing point in a section of the chassis that has not been designed for it. To make matters worse, you have lifted weight off each end of the springs but you don't know how much. You have narrowed the main load bearing point on the chassis down to a single point above the axle instead of the factory designed four widely spaced points. As the weight bears down behind the air bags, the rear end of the spring is no longer giving the end of the chassis as much support as it should be and, as the chassis tries to pivot and lift the front, the front end of the spring can't help much either because the chassis is going up, not down onto it.
The only way to get your car back up again is with heavier springs but even that creates problems. The car becomes tail heavy which does not help handling and I would imagine the brake pressure proportioning valve would be applying minimum pressure to the rear brakes when you really need maximum. This could result in the back of the car trying to overtake the front in a big way in a high speed panic stop.
Your problems are coming from the way you have the car loaded and if you only have one or two average weight people in the front, you are going to have to have a complete rethink about which way to go.
A stock standard dual cab is designed to carry X amount of weight to bring it up to GVM. In order to get it up to that level, every load bearing section of the car has to be used to the maximum. That means heavy people in all five seats, a full fuel tank and the rest on the tray with the heaviest items at the front. That should leave the car low down on its suspension but fairly level. If the rear is still down then some of the weight will have to be taken off and heavier people put in the cabin. Of course that is not always possible but if you can't get enough weight into the front then you can't take the car up to GVM and expect it to be level. The weight must be evenly distributed, not most of it at one end.
If Toyota was to carry out a loading demonstration, you could bet they would start with a couple of sumo wrestlers in the front seats and go from there.
If I was in your situation and I really needed that much gear in the back then I would be using a box trailer. A good little off road trailer with up to about half a ton in it should leave you well under maximum weight in the car and nowhere near maximum towing capacity giving you a high level of safety and vehicle reliability.
You asked for reasons so I hope this has explained it fairly well.
banshee
yep you will notice the difference....i got em in my nissan (alot heavier thatn your luxxi) and don't need them most the time but when you load her up, pump it up and your away...
blackout
The air bags work in conjunction WITH the spring they should be inflated to the recommended pressure and therefore creating a bump stop or air cushion like situation.
The air bag is designed to give and flex, they are and should not be solid and therefore create a load point either end.
The load points are now distributed across the Leaf and Air Bag.
Bello
I have airbags on my Pathfinder, for towing Caravan, I also use Weight Distribution bars. The Bags stiffen up the rear, they don't lift it. I have also upgraded the suspension, shockies and springs, gave a 40mm lift.
I had bags on my last 4b, just for the caravan. Would not be with out them.
Bello
4wdsupplies
Airbags have there place and if used properly work a treat, however in my personal opinion I would not put them in a leaf sprung car for the reasons mentioned above. There are plenty of photos etc around of utes bending chassis due to airbags. probably all used the wrong way but there is always that risk.
Maybe even look into helper springs. my uncle has some little springs not sure what they are called but they work well for him.
cruising62
read my post under chassis-air bags,dont go there.last post is on page 2 half way down
Traveller
How much weight are you putting in/on the vehicle? As many above have mentioned there can be a downside to using airbags! I have and currently do run a set in mine(a GU) and they are great if used within limits. Just make sure you know what they are!!
Liloking
I'm researching this airbag subject myself for the rear of my NT Pajero which has independent coil suspension. I'm having a full off road caravan being built which is why I'm reading everything on this area so I can make an informed decision. I'm also looking at upgrading my current suspension for the upcoming trip around Australia including the Gibb River Road, Mitchell Plateau, etc. Any advice would be most welcome
Chatty
I've got Polyairs on my NS - this is the 3rd or 4th vehicle I have had with them - highly recommended,
As long as you realise that they don't give you extra loading capacity - they simply allow the vehicle to ride higher at the back as you approach max load.
And they are great for towing - the vehicle is more stable with them.
Chatty
I should have said that an ex MM engineer here in Adelaide told me that the Poly Airs are good on the Paj, as the CVs can quickly get killed by heavy loading flexing the axles upwards - he says the axles need to angle downwards.
Liloking
Thanks Chatty, that was very helpful and will be taken into consideration for the final decision. I'll put the end result on this community for all to read.
Regards Liloking
Jackolux
Air Bags fitted to a vehicle that has rear coil springs , is very different to one with leaf springs . Hilux's have a low GVM 2850kg . What you need to do before you spend any money , is load it up with all the crap you intend carrying , take it to a Spring Works and let them have a look , they will be able to sort it for you . Forget the airbags .
Run it over a weigh bridge ,you will get a shock , it will be well over GVM ,
Mark167
in my opinion (having heavy duty coils in the rear supporting the leaves) idd opt out to get air bags. having the option to pump up or release the air bag is music to my ears. mind you im not sure about them problems you can get from use of the airbags.
stevemc181
There is at least one specialist 4wd insurer who will refuse to insure any vehicle with rear leafs and air bags. That fact alone has to tell you something?
Coils and airbags are no problem as you aren't adding a pivot point and adding stress to a section of chassis that wasn't intended to bear the additional load. When off-road, I run lower pressures in the bags to give the rear suspension a bit of sympathy and let the coils do their job.
2luxes
Liloking
This article should be essential reading for anyone getting into caravans.
http://caravanandmotorhomebooks.com/caravan-and-tow-vehicle-dynamics/
The following is an extract from it. Do not stiffen the rear suspension on a car without doing exactly the same to the front end.
“Stiffening the rear springs or adding rear airbags without doing so proportionally at the front, transfers more of the roll couple (roll resistance) to the rear suspension. This yet further loads up the outer rear tyre whilst cornering, thus increasing its slip angle. Here again if that footprint collapses or slides there is a very real risk of jack-knifing. This is not theoretical conjecture. It happens.
Because of the above, vehicle manufacturer’s intended front/rear slip angle relationship should not be changed. If the rear suspension is stiffened (or air bags fitted), so should the front to the same degree (or a stiffer roll bar added) to maintain the intended roll resistance balance.
Minor spring rate changes are rarely detectable in normal driving. This is why so many people claim it’s safe. But if understeer is reduced (by say, stiffening the rear springing alone) the then close to neutrally steering vehicle can be triggered into terminal oversteer by a sudden strong yaw force.
Generally speaking, passenger vehicle suspensions that appear to need upgrading are being used for loads other than they are intended to carry. Suspension changes require serious engineering expertise – not buying airbags on eBay.”
You have not said how much your van will weigh. This guide might help.
http://caravanbuyersguide.com.au/tow-vehicle-caravan-weight/
Another point is check with Mitsubishi to see if they have any restrictions on the off road towing capacity of the Pajero. They do with the Triton. I have seen an email from them saying the maximum specified capacity of the Triton is for good sealed road conditions only and they don’t recommend towing it off road. You will have to contact them (the company that is, not a dealer) to see what they mean by “off road”.
I contacted the manufacturer of my car and they had a few restrictions. I would imagine they all have some.
As an example the off road towing capacity for the Land Rover Defender comes down from 3500 kg on road to only 1500 kg off road. The specifications for the Defender on the company web site say 150 kg on the tow ball puts 206 kg onto the rear axle. That would be one reason for the capacity reduction. Stress on the drive train and cooling system would be some of the others. Imagine what 300 kg or more on the tow ball would put on the axle. That is just stationary weight. It would be considerably higher when it is bouncing up and down.
Some of the ball weight can be lifted off the axle with a WDH and redistributed between the front wheels of the car and the wheels of the caravan but a WDH can not be used in some off road conditions.
Remember an air bag is an exponential spring, not a linear spring like your coils.
Liloking
Hey 2luxes, I have found this article both enlightening and challenging. I will most certainly be giving Mitsubishi a call to build on the info you have supplied in your article, I appreciate your time you have put into this article.
Unfortunately my brother-in-law has already installed airbags in the rear of his 2014 Pajero in preparation for doing this trip with us. I would also like to thank stevemc181 for his input as a fellow Pajero owner.
