Aftermarket rear dampener length issues with coil springs
Ent
Just a few words of warning when sourcing aftermarket dampeners for rear coil spring vehicles. In many designs the downward suspension travel is limited by the dampener. Many after market dampeners are longer than factory dampeners. This can result in,
1. Brake lines being stressed
2. Coils unsetting
Dobinson on their suspension setup limit damper length increase to 20mm and also increase the spring free height to 20mm so generally speaking the above should not be an issue.
Bilstein on the PB/PC Mitsubishi Challenger are 35mm longer than factory dampeners so the above can be an issue.
I went for Drummond Motor Sport dampeners and they were shipped 55mm longer so brake lines needed replacement along with diff locker and breather lines with custom springs requiring to be made.
Just something to watch for as often this issue is not mentioned.
