Well, after giving advice to others for the past 6 months or more about securing your expensive spotties (and other bolt on accessories), I finally got around to doing my LF HIDs this morning.
Drilled into stainless fitting bolts to the nudge bar and to the LF mount bolts too, and inserted a 1/8" stainless rivet . . . designed to stuff up any thieving scum trying to undo them in the dark with a spanner.
At least they'd have to have a cordless drill with a good quality drill bit to get these out.
Did bolts to the nudge mount brackets too, as well as to the chassis, so they can't unbolt the lot with the bar either !!
Tell you what, drilling into the bolts is bloody difficult to do, especially at the awkward angles you need to work with.
Going to a Hackham pub tonight for wedding / reception, so thought great opportunity to get this job done, as it will probably get tested tonight
