92 Hilux headlight upgrade options
jimdapom
Hey all
I went to put some brighter globes in my truck today only to discover that the headlights are a sealed unit and the bulbs cant be easily changed. I would really like better performance from the headlights without having to use the spotlights so much.
I have been looking at a few replacement units with removable globes and thought I'd ask for opinions/advice on what I've found. Im not really in the market for anything too expensive at the moment, but I don't want to skimp too much and end up with something thats going to break as soon I hit a bump (or a creek crossing)
Heres a few options I have found so far....
82-95 Toyota Pickup 7x6 Angel Eye Headlights Headlamps Assembly 10000K HID 92 - Headlights - Lighting - Pickup - Toyota | EverythingCarParts.com
82-95 Toyota Pickup 7x6 H6054 Projector Headlights Head Lamps Assembly Black - Headlights - Lighting - Pickup - Toyota | EverythingCarParts.com
I really like the look of these ones too....
82-95 Toyota Pickup 7x6 Projector Headlights Headlamps Assembly 10000K HID - Pickup - Toyota - Headlights - Lighting | EverythingCarParts.com
Being a pom :( any pointers on legalities (in QLD) for this sort of mod would be appreciated as the rules on modifying in Aus seem to be pretty strict when it comes to some things.
Thanks in advance Fourby Guru's :D
bluehilux
Banned
Strange that they are sealed.. My 91 hilux have bulbs and i put the +30 clear white (tried the blue tint ones and in the wet they are no good) in and they are a bit better.
I got some 100/55 H4 that will go in later as i want to add a relay/wiring loom for them.
Neddysmith
I have a 91 lux and it also has sealed beams, I would think just getting the light housing and converting to h4 globes should be enough for what you want and most likely a lot cheaper.
muc the truck
my in-laws 2002 Hilux had sealed beams from new, they bought it new . I was shocked to see sealed beams in it when I went to change a bulb for them . ended up tossing them out and fitting h4 housings. Toyota are lousy with lights in base models
bluehilux
Banned
I got it when it was 18months old.. it was a council ute. They were in it then.
I assumed they all had them till i read this topic.
croozza
HID is illegal to have as your headlight, so steer clear of them, depending on the year and model of your Lux, will depict what lights were put in, if you have either semi sealed or sealed, you will both benefit with the fitment of better quality optics in the headlight, Narva do a very good headlight replacement, as well as if you put in the Narva +120 bulbs, with that you can increase your light output even further by upgrading the wiring loom, this will keep you legal and out of the bad books with the cops.
Forget about the projector style lights as you actually have less light output than std lights.
Another thing to remember is to readjust your lights, they will need to be adjusted down slightly, otherwise you will be getting people hi beaming you all the time and that will get annoying after a while.
jimdapom
I've never seen them sealed like that before either :confused:
I suppose it's a good idea to have them sealed when the car plays at being a submarine but not very practical when you need to change one at the side of the road!
Although I think those black projector ones would look awesome on the truck but it's still gonna leave me with the same replacement issue. Also I wouldn't want to be wasting police time by being pulled up on them ;)
Maybe just the crystal ones are the way forward....
Thanks for the input guys. I bet there will be a few people in the garage having a look at theirs now! :p
muc the truck
That site looks american so frieght might hike up the price.
Have you look at these?
My 03 'lux also has sealed beam.
Toyota Hilux Headlights Headlamps Rectangle Crystal Pair 83 05 7x5" Brand NEW | eBay
the crystal clear headlights are not to be used on road. they have no directional lenses just a clear pain of glass. you can be defected for them on the spot . there are cheap ones made from the same company with focus lenses that look similar to original and they are the ones to buy. Hela make excellent ones and the chrome on the reflector lasts a long time. I have some 25 years old.
muc the truck
anything brighter than 65 watt halogen is illegal for headlights on the headlight board.
narva+120 fail in most headlights as there too bright and flare just like hid does . Its news to me that projector lights have less output because most I have seen come with hid set up which for those that don't know is 2-3 times brighter than the halogen bulbs .the others that have halogen are focused better. You can legally have hid in headlights . You need projector type lenses and a headlight wiper set up retro fitted from another car.
If hid projector lights were not brighter there would be no requirement to have wipers to keep water droplets of the face of the headlight to stop glare and dazzle. Hid / halogen hybrid kits are available so you have a normal halogen bulb on low beam and a halogen on high been . some may argue that's bad and its still illegal unless its fitted with wipers and projector but in your eyes and mine its no worse than having a set of spotties coming for you because the dill didn't dip his lights.
dipping lights is the most important part of night driving . tell the latest Toyota Camry hid drivers that .
croozza
The Narva +120 does not have a higher output, so they don't flare and fail, they are still only 60w, I think your getting confused with higher wattage bulbs.
HID is illegal for vehicles with single headlights due to the high beam needs to be separate (and it would be very costly to put in a washer system for your headlights).
Projector style headlights do not increase the light output of your headlight, just look at all the projector style lights out there, all of them do not have projection for the high beam side, they all still use normal reflectors. as this model Hilux only has single headlights, if he was to use projector style lights he will loose light output.
muc the truck
the only difference in light out put between hid and narva 120 is hid is 3 times as bright as halogen while narva 120 are 120% brighter than halogen which is more than twice as bright as halogen.
grab your narva 120 and place it in front of a light tester with wet headlights , it will flare off the board just as hid does. gas changes things its not just about wattage anymore
personally I couldn't care what lights people have as long as they dip them .
Just like a focusable creed led torch the magnifying lenses controls the light pattern instead of a reflector. pin point focus it and it bright I assure you. and its just a cost point of view that some hid projector equipped cars only have it for one and not the other. high end cars have had both for some time and each spread a different light pattern to suit the application . there are triple hid projector lights available for hilux type headlight's but there 900 dollars on ebay.
