adam10_1990
being that my pwado is full time 4x4 (so its basically an awd) will i have trouble installing auto lockers? if so whats my options, i dont wanna have to spend mega bucks on a arb airlocker
You will have no problems if you only put it in the rear.
However, you will get lots of understeer especially on wet roads, and the front passenger tyre will wear out alot quicker than the others.
Im more worried that putting one in the front is bad, as its awd, (not a 2wd) but it looks like i have to go a arb airlocker. In the front at any case. and i dont mind the slight slide in the bum, im one of the guys who goes out onto the tracl at qr in high powered cars![]()
Greetings Adam,
Sorry Mate Can't Put A "lokka" Or Auto Locker In A Prado, You'll Have To Go An "arb/tjm" Air Locker Or An "eaton" Electric Locker.
Cheers Bouncy
Greetings Adam,
Sorry Mate Can't Put A "lokka" Or Auto Locker In A Prado, You'll Have To Go An "arb/tjm" Air Locker Or An "eaton" Electric Locker. Even If You Fit free Wheelin Hubs Doesn't Help Because Drive Is Sent To The Least Restrictive Axle Through The Centre Diff, So You Will Just Spin The Front Tailshaft.
Cheers Bouncy
Never heard of the eaton electric locker, is it the same as an arb locker just electric as opposed to air
That would be a yes plus an tad cheaper
Stick One In The Back ! No Problems.
Check 4wd Systems Model Listing.
Cheers Bouncy
Not just 4wd systems that sell them, there are other brands of auto lockers out there.
Also to your earlier post about free wheel hubs, there is no possable way you can put free wheel hubs on a Prado, the Prado hub is way to big to fit a free wheel hub.
That's Right Adam,
So You Don't Need To Wire Up A Compressor, And No Air Line To Damage.
Silent Operation, No Noises Or Clicking, Just Flick A Switch And Power Is Sent To The Electro-magnet, And The Diff Is Locked. Also Shorter Fitting Time Because No Compressor To Mount. You Still Need To Drill A Hole Through The Diff For The Wire, Same As An Air Line, But Less Fiddly.
Cheers Bouncy
OPPOSITE LOCK Supply Them Adam.
Cheers Bouncy
