80 SERIES DUEL FUEL GAS TANK
macka17
depending on size.
Cut lengthways. some slots along bottom of one. Hinges to other to use as windbreak/lid.
Cross Droppers welded on each end. drill a few holes.
Weldmesh. Coals/gas rings. Cast barby plate x 1 x 2 x 3.
Yeaaaay. Barbie time.
I've done it with a coupla stainless beer kegs
and the last 110ltr gas tank from Fairlane boot.
you can get them tested and restamped for a Road worthy, if your keeping the car and its already in your name don't worry about it being out of date
or a BBQ is also a good option just make sure it is totally empty before cutting it up:rolleyes:
rogerazz
Just get it tested and re stamped if its any good and you need it. Otherwise you can hand it in at a gas outlet but you will pay for it's disposal. Maybe do a deal.
muc the truck
Hi there, anybody know what to do about an out of date LPG tank, without stating the obvious
Take it out of the car , drive it to a scuba dive /gas bottle inspection station , have it certified . refit the tank and then take it to a LPG auto shop to have the vehicles lpg compliance plate changed for a new one that will last another ten years . Once the lpg isolation tap is turned off it can be disconnected as simple as a gas bbq bottle to a bbq
