75 series rear axle dowel upgrade
troopinion
No more broken axle studs,Coastline Engineering on the central coast put my axles and hubs in their milling machine and drilled four precision tap in fit holes for the Toyota 10mm locating dowels for around $200.If you want yours done you can contact them on BH 0405148399. I also bought Nitro chromemoly axles and ARP chromemoly studs from Lockedup 4X4.
Gavo
Yep smart upgrade.
Much better way to do it then the old cordless in the driveway (which is more common than you would think).
troopinion
tried hand drilling an old hub for practice with a 9.92mm drill then ream it with a 10mm drill,still didnt fit accuritely. on a milling machine is the only proper way.
Aaron Schubert
Nice work. Pretty common upgrade. How many times did you break studs?
I haven't had to yet. Whether that's just good luck or not I don't know. They say the nut torque and wheel bearing backlash is critical to ensuring they don't snap.
I doubt you will break these though!
Aaron
ian.c
I once had all shear off and the axle juat slid out, it was caused by the wheel bearings not being tightened as they wore over time, this was just after I bought my first hj60, I now regularly check and grease all my bearings and havent had a problem since.
Ive also read about upgrading to a larger diameter stud, has anyone done this?
troopinion
Aaron
heaps of times, i have an automatic diff lock fitted,they sometimes go in with a bang which puts strain on the axle studs and locating dowels
troopinion
troopinion
you cant fit 10mm studs the cone washers are larger than the axle flange the only way is 10mm high tensile bolts where the shank of the bolt becomes the locator.need to drill right size hole for 10mm thread then drill 10mm hole in hub and axle flange to take 10mm bolt flange.
ian.c
Thanks mate, I didn't think there would be much left on the flange after boring out, just do away with those bloody pain in the ass cone washers.:)
