60 series suspension
walker85
hi there all i'm new to this site. i wanted to know if anyone knows how i can get my springs up higher of the ground with out doing leaf over. i'm runing 33 inc muddies but the springs still hit the ground.
BILLBY
hi
well there is a few options open for you ,try a 2'' spring lift maybe 500 to 800 then maybe a 2'' extented shackle replacement cheap option around a 120 to 160 per pair? for some body lift 50 mm spacers give a good look they are about 220 and might include high tensile bolts good if you are running a bigger tyre they lift you again,so there you go there is plenty of options this is just a variety of quick stuff
:cool:
ps the 60s rock
walker85
thanks mate but it's the bottom of the sorings that are hiting the ground need to get them away from the ground. thinking of trying to 80 series suspension in if anyone knows how to do it
landabuser
yeah man what springs you running at the moment i saw a 60 series with extended shackles didnt look to bad but maybe upgrade to 35's and 2inch body lift
