Wow what a crap fight I am guessing Friday night and everyone had a few and decided to play on the net - not to worry we have all done it
Firstly who has a socket and can help the bloke out? I have one but I am on the northside of Brissy - A proper socket for the job not a Ebay ratteling good fit one, might as well use a hammer and cold chiesel if you are going to use an ebay one!
Second if you guys were true mechanics you would know this model car wasn't released with ABS therefore that part was just a b/shit argument.
Also 6nm torgue is that in the manual? (I have adjusted just a couple of Nissan bearings in my time and have never heard of this but have discussed at length putting preload on wheel bearings to save needing to adjust in 5000km - now that wuld be a good discussion point.)
My suggestion is do as big wrig has mentioned - use a pin punch, cold chiesel or whatever method works and remove the nuts (BTW have you folded the tab back up that holds the nuts in position?) Don't waste your money on a socket. Now for the big part - Spend the money and upgrade the nuts to the GU system which doesn't have the nuts and dosn't have the washers you need to fold the tabs on they have backing plates and little screws to hold the nuts in position. A much superior system
