You need to find a gps app for your iphone to be able to load tracks onto it (iphone cant do it alone)
The app you get decides what its compatible with (some might only do 1 or 2 formats, some will do many - GPX format is the most common overall I guess)
For example, if you want to view them on your computer and you like using the "Google Earth" program - Then a KML or KMZ format track would be perfect (its a format made by google earth)
If you run google earth on your iphone, same applies with kmz/kml being a good choice - although i think it also handles gpx
I use "gps kit" app on my iphone personally (compatible with quite alot of GPS formats, and it can make its own tracks while you drive as well - it also has options for lots of different map styles - eg google satellite/hybrid etc)
To get them loaded into the iphone GPS app you have chosen, simply download the track file in the format you want using your computer - and email the track file to your iphone as a attachment - then open the email attachment on your phone and tell it to "open with" whatever gps app you chose to install and use
If you using a car GPS unit - you need to know what formats its capable of, then download in that format - Then read your GPS manual on how to get the file loaded onto the GPS unit itself (generally involves plugging the GPS unit into your computer, and sticking the track file into a certain directory on your GPS unit - or perhaps the software that came with your GPS unit has the ability as a menu option to upload a gps track to the unit)
I think this has been covered quite a bit in the past which is probably why you didnt get answers for a while (it takes longer for somebody to type the instructions out than it does for you to use the "search"
) I know Ive explained it quite alot in the past in other peoples posts - I would of thought there was a sticky by now or somthing? (perhaps not)
Just so your aware - if you click on the GPS track file you want on this website using your internet browser - The internet browser might try to "open" the file VS downloading a copy (you want to download the file not open it)
If you get a page of "gibberish" in your browser - thats whats happening (the "gibberish" is actually the GPS file! - being opened instead of saved to the desktop)
If this happens, you need to select all the "gibberish" then copy it to your clipboard, then create a new notepad file on your desktop and "paste" the gibberish in, then save the file, then rename the file extension to match the format you downloaded - So if you originally tried to get a .GPX file you might rename this
"gps track i downloaded.txt" into this "gps track i downloaded.GPX"
If you guys are really struggling - PM me a link to the track you want and let me know what format you need - I can do the legwork and email you the trackfile (dont forget to give me a email address lol)
If you rename the file extension from .txt (notepad type) to .GPX on your desktop after pasting the "gibberish" in - but the desktop icon still shows a notepad text file - you didnt rename the file extension at all, infact you just renamed the filename itself only and you have actually ended up with "gps track i downloaded.gpx.txt" which is still a text file. (instead of "gps track i downloaded.gpx" which is correct)
In this case you need to turn the option to "hide extensions for known filetypes" in windows settings to "off" (you cant rename the extension if windows automatically hides it from view - you can only rename the file name itself unless that option is turned off)
God I hope i havnt just confused you guys more hahahhaha
