4wd engaging problem
christo
Hey.
just a question in regards engaging hi 4wd on a 05 triton.petrol manual1 autolock hubs.
all good till today, will go into lo 4wd and out.
but when trying hi 4wd light flashes on and off but not engaging.
Grrrrrr!
mrtriton
i would test your vacuum solenoids they are a common problem, also the transfer switches tend to fail, thats where i would start bt there is not much to the system so its usaully not too hard to find the issue
have fun and good luck
triton05
the light only indicates were the shifter is and they play up alot,as the other guy said check your vacuum line on the soleniod on rear of k frame but i would drive on some wet grass to see if engaged i would say it probably is just a faulty light switch as you say you are getting low range.:)
prawns
My 4wd lights flash and playup sometimes after driving through mud/water. One time it played up for a week - until I did another water crossing and suddenly the lights locked on properly again so I assume it washed some gunk off somewhere (my lights were flashing but i was definatly in 4wd mode properly)
I got a 93 pajero probably a pretty similar system to yours - sometimes reversing back and forwards helps the lights stay locked on as well (and if the diff light keeps flashing try wiggling the steering wheel side to side while moving seems to help also)
Grey Ghost
Like the others have said, my 05 Triton seems to have issues with the 4wd indicator after going though mud puddles, but it definately has got 4wd engaged, it's just the bl@@dy light that doesn't do what it should - after a big mud puddle the indicator will flash, if I'm in 4wd or 2wd it doesn't matter but it's pretty easy to tell if the front wheels are helping pull you up the next hill or not.
prawns
Doing a water crossing has always fixed mine straight up when they keep flashing like that (well its immediatly worked the 4 times Ive had to try it ) - I dont have to wait for it to dry either which makes me think its crud blocking a shaft moving properly or somthing (in my case at least)
Maybe grabbing a hose and trying to wash off the underside of your car might be worth a try if you dont have a creek/water crossing somewhere nearby
I read this website below which is why I originally tried the water crossing trick (stuck actuator I think in my case maybe never really looked into it once I found out driving through a local water crossing sorts mine out quicksmart)
Great info with pics on the vacuum hoses etc as well as other things to check - Its for a pajero super select system which is the same system the triton has? so hopefully it all looks kinda similar
Pajero 4x4 - 4wd offroad
Bayraider
Hey guys. I have a MK 05 Turbo Diesel and had a problem where when I slowed down I got a whining noise from the diff and when i stopped it clunked and my 4x4 light flashed. I noticed that my battery was getting flat so i changed it and the problem went away. I was talking to a sparky mate and he rekons they have relays that engage the 4x4 so when the battery starts to get flat the relays can switch.
Grey Ghost
The 4wd system in these beasts is mechanically/vacuum diven so a flat battery should not affect it, the indicator light may not work with a dodgy battery but thats about all, haven't go some kind of e-locker (electrical diff lock) in it by any chance?
