4wd accessories installer
fraz91
Depends on the accessories you're looking at getting fitted and where you're located. Most mechanical workshops will be able to fit your accessories without too much hassle, and some will even source them for you. If you're really lucky, they'll even try and get you a bit of a discount over the RRP to help look after you.
If you're in the south-west area, then I'd recommend Ultimate Suspension as their customer service is second to none. I know quite a few people who have had work done to their vehicles by these guys and they simply rave about the quality of the work and the customer service offered.
multimaster
have a look at the instructions and see if you wouldn't be happy to do it yourself, the spotties aren't too tricky, and there aren't many mistakes to be made if you follow the instructions. The snorkel on the otherhand is something you want to get right, you should have got a template with it and the tools you need to install it won't cost the world. If you want someone to do it, I'd go to an auto-elec for the spotties and go to the bloke you got the snorkel off to put it on.
James
dimeglio
The bloke i got the snorkel is in qld and im in syd so a bit hard
Fraz91 do you guys install snorkels as well and spotties can you ask brendan how much if you guys do?
