That's what's written in my service book .Hi muc
Is this a must every 40k ? As in part of a new cars book service schedule
It must be a lot more than $800 because as a jok I asked them how much to just do the rockers and it was just under $800 which is hideously expensive considering parts cost me 160 and it took about 2 hours to do taking my time with 2 cups of coffee and a biscuit .Hmm I wonder what there cap servicing cost is ?
I would question that . I bought the parts required.Hmmm. 2010 Auto.
My local bloke did mine on 80k service. Paid separately done separately in some slack time.
$270
You simply don't understand this JOB. The injector seals and rocker gasket part numbers I listed here stop oil getting out of your rocker cover . The injectors on this engine pass through the rocker cover and you should not reuse these seals as heat makes them rather Hard compared to new . Genuine workshop manual says pacifically to replace these seals each time the rocker cover is removed.Hmm.
I've done a few heads over the yrs.
Never popped injectors to do tappets.
Unless retipping them if dribbling, or lapping the valves..
It's just normally. Injector pipes if over rocker. or leak off pipes.
Rocker cover off Check tappets. Shims etc.
New rocker gasket. replace lines. bleed if had to,
then kick it over.
Or are they different.
My Patrol did over 300k and never had then done.
I could be wrong. I'll dig out rec'ts and check.oK.
Maybe $270 plus.(parts?)
ebay has them for about $10 that's were I got mine from .easy to find one for the PK Ranger but like a bloody needle in a haystack for Isuzu
For a 2014 MUX? Never seen a workshop manual for a current model Dmax or MUX. Would love a link if you have one. Gave up searching.ebay has them for about $10 that's were I got mine from .
