4.88 vs 5.13 gearing
CHUAH
Hi,
I know there are not too many Jeep JK Wrangler drivers on this forum however, if you have any knowledge or feeback / experience please share them with me!
I am running 35" tyres (315/70/17) on my Jk Wrangler 3.8l v6 automatic transmission. I do tow a caravan and go 4wding as well as use this car as a daily driver....
I have been researching between 4.88 and 5.13 gearing and still can't decide which one to go with...... 5.13 is weaker due to the gear however, no one has every come accross any broken gears....(search all over the internet) everyone seems to be recommanding for a auto + 35" = 5.13.
Revs are ok, I'm not fuss on sitting at about 2380rpm on 70mph... it's more of a matter of who has had problems with the 5.13
I've also attached a chart showing the gearing vs rpms etc.... how accurate can we count on these type of chart??
Any info would help.
Cheers!
Bainsy
Wow i dont know how accurate that chart is but iv got 4.88s running 36s (more like 37's on road pressures) and it screams its head off at 100km/h. 5 speed overdriven manual. This doesnt bother me as its rarely on a main road. I got 4.88s so i could run 38s but couldnt affort the 2extra inches of rubber at the time. Does ur auto have a big overdrive or 2nd overdrive or somthing?
CHUAH
that's why I'm confused........ I have guys like you saying one thing and other Jeep drivers saying another....... maybe there's something else we're not taking into consideration..???
My is 3 gears auto with 4th being overdrive.... I know auto is totally different than manual so as to what the graph is showing as well.... but what you're saying is also totally different then what others are saying etc...
I know the gears are probably weaker being a 5.13 but I can't find anywhere in any forum (locally or overseas) that they have broken a gear because of the weakness of teh 5.13 in a D30 front diff in a Jeep JK Wrangler........
I just need to find someone locally who has done it so I can test drive it myself.... ALL USA website forum for Jeeps totally recommands 5.13 for 35" and auto transmission...
HGturbo
I run 36" tires, 4.88 gears, 5 speed manual and at 100kph I'm revving at 2650rpm.
If your only revving at 2380rpm with 5.13 then that is awesome.
Is that in your motor's "good" rev zone ?
CHUAH
Once again the manual is totally different that auto (well i'm talking about my jeep anyway....) and yes, it is reving in the "good" zone! I don't even care if it revs 2500!
From what I have read, 36/37" tyres and manual you should be running 4.56??
Anyway, 90% says go 5.13 10% says I'm crazy if I do..... just don't want to get the wrong gears as they are bloody expensive to fit etc....... also putting a rear arb locker in the rear diff as it's a D44 and much stronger then the front being a D30...
ruffy01
Hi there chuah1.
Those charts appear to be pretty good, they are relevant to the JK Wrangler with it's overdriven auto. Fourth gear is 0.69:1 which is why your rev's are alot lower at highway speed than could be expected.
Be aware the calculated RPM is based upon the Torque Converter 'locking up' at highway speeds, which it should but in my XJ no longer does. Hence actual RPM may be ~300 rev's higher.
Formula for calculating Velocity at RPM: V=(RPM*60*Pi*D) / (1000*Diff Ratio)
Simplified: RPM=(208.86*V*DiffRatio*OverdriveRatio) / Tyre Diameter
Enter Velocity (V) in KmH & Tyre Diameter in inches and your RPM will be given assuming no slippage through the Auto or Converter.
Eg. 100Kmh, 4.88 Diff Ratio, 35" Tyres = 2912 RPM with no overdrive, but your 0.69:1 overdrive means 2912 RPM * 0.69 = 2009 RPM.
Hope that helps & doesn't make it confusing :)
flexytj
4.88s are ample for 35-37 inch tyres on the jk .
if you go to 5.13s the teeth on the pinion gear get on the small side
which isnt good for strength .
Howie
4.88 or 5.13
hi CHUAH1,
really really interested in how you went with this as i'm in the exact same predicament with my JK 4 droor auto.
i appreciate that the post was a while ago, but if you could share how you went, that would be fantastic!
everyone is saying go with the 513, but i also like to drive some long distance on the black and i really don't know how i my JK will be sitting at 100 + kph.....thank-you in advance,:eek:
muc the truck
Hi,
Cheers!
towing you van i suguest 5.13 this will protect your gearbox and prevent engine labouring . you have to do the maths your tyres are x amount bigger than standard so the diff needs to be x amount lower in ratio than standard . people often run un moded on big tyres BUT THEY NEVER TOW. and besides you can eat eveyone alive rock crawling
Big Rig
No way, 5.13 is way too much. 4.88 even. 4.56 plenty for 35's. I'm running 35's on a 12 unlimited rubicon with 4.11's. I am stepping up to 37's and will go 4.56's.
In any case, the point is Mute! He sold the car:)
muc the truck
what is the original ratio and tyre size out of the shop?
CHUAH
Hi Howie,
Just only read your post about 10 months later... Lol
Never found out as I sold the Jeep!
Sent from my iPhone using Tapatalk - now Free
