3rd row seats
watto1772
Hi there, everyone, just a quick post to see if anyone has had hassles getting the 3rd row seats out of a pajero NM ? there seems to be a bolt further back which is in a difficult spot .
or has anyone done something different? so i can utilise that space for recoery gear etc.
cheers watto
croozza
cheers watto
Sometimes either folding up or down the seat gives better access to the bolt.;)
Davidman
Pulled the rear seats out of my Pajero not long after buying it. Like Croozza said, undo the bolts you can with the seat in one position, then move the seat and undo the others. You may have to push the seat a bit to access the last bolt on each side.
Half the time I go camping, I pull out the next row of seats too, gives so much extra room, and it's only 3 bolts and 1 nut per rear seat.
croozza
I loved my old 80 series, when I wanted the 3rd row out it was just a leaver, you get them out in a matter of seconds, same with putting them back in. My Prado is just a little bit harder.
croozza
thanks guys, I'll give that a go, I'd take out the second set but I think my son would be a bit unhappy:)
Think long and hard before removing the second row seats, because here in QLD you have to get a mod plate fitted, don't know about the other states.
but it is fine to remove the 3rd row seats.
