2020 Mazda lift kit
XavierTahiti
Hi guys!
I’m looking for a lift kit for my 3.2L BT50, what do you recommend ?
I hesitate between going on a budget a fitting a 200$ spacer lift kit (from perfect lift), or going big and choosing a Fox Shox lift kit from VMN :https://www.vmn.com.au/fox-50-75mm-suspension-lift-kit-suit-mazda-bt50.html
What do you think about it ?
The aim is juste to lift the car to make it a little bit more offroad capable, for our mountains out there in Tahiti. I won’t be carrying heavy weights or mounting a heavy duty bumper.
I might be going for 33’ tires after the lift
thanks!
xavier
Suppose check local laws re how far you can go with suspension and / or body lift, maybe Tahiti is pretty lax, or who knows.
The BEST lift is wheels / tyres increase in rolling diameter for real diff clearance, but again most jurisdictions have limits on how far you can go, also you will kill a bit of fuel economy, braking distance, travel / steering and body contact needs to be considered.
Next best would be a suspension lift, 50mm is pretty standard here in Oz for non engineered lift.
Body lift with blocks gives some benefits, but it's really more of a boys thing, makes the vehciel LOOK lifted, but not too many real off road benefits.
Increases body roll driving on road (cornering), makes vehicle a little more top heavy and possibly prone to tipping easier on steep inclines if side on.
As with most things 4x4, moderation is the key.
Maybe a slight increase in rolling dia (10% ?) and a 50mm lift kit.
Welcome to the forum again Xavier.
XavierTahiti
Thanks for your answer! :)
Yeah, there aren’t really any real local law about modifying a vehicle, in Tahiti, so it will be OK (we’ve got some rangers with 35-37’ tires, 4’’ suspension lift and additional body lift.. lol looks pretty uggly, but some people likes it! Lol)
I was going to mount Hankook 33’’ tires on the bt50 (RF10 or RT03, haven’t decided yet)
what brand or model would you recommend for the 50mm lift kit ?
I'd do mostly wheels tyres within the 10%.
Lift kit. Any of the big brands.
I had a Rockcrawler 2", got me 40mm rear, and this helped with rear loads, I kept the front wound up only 25mm to match loaded rear, as winding up too high = too bigger CV angles, chew them out if too much angle.
I wouldn't recommend the Rockcrawler though, the rear springs were shite really, always inverse.
Ended up breaking a top leaf too.
Ended up changing them out for great leaf packs from SSA in Brisbane . . . https://ssa.com.au/suspension-products/
They were so good, same lift, but rear leaf packs, and cheap !!
These were AUD$505 in early 2019, inc new bushes and ubolt kit.
Fitted my self, a hoist is a must for this.
This was the rockcrawler leaf comparison to the new SSA when I swapped out . . .
You could leave the front torsion bars standard, if not putting anything heavy on the front.
Wind them up the 20mm - 25mm and sweet.
Mine were heavy duty torsions, only a mm or so thicker, but gave it a pretty hard front ride, I only had an ali nudge, spots, nothing heavy.
Some brands you can look up for kits, if not interested in doing the rear leafs as above and leaving stock front (wound up a bit) . . .
SSA as above do ALL sorts of suspension, inc torsion bars, so first up email them and ask for their recommendations.
They'll all want to know what you have fitted, what you want to fit, constant weight you want to carry in the rear, etc.
Others that are well known.
Ironman
ARB / OME
Dobinsons
Tough Dog
EFS
Probably more if other members have their input.
