2012 BT50 Suspension advice required
Neil58
Have BT50 with 18,000 klms on clock but not happy at all when any load over 250kg on rear. Sags very badly. Mazda not interested in problem. Have BFG AT tyres and 60l watertank on rear. Any ideas apart from airbags. thanks
MatOZ
If its fairly new and you want to keep warranty, check with dealer first before you spend money on airbags. Most manufactures wont accept them if chassis cracks and bends develop.
If that dont concern you i here many people think they are great and swear by them.
mac_man_luke
Just put heavier springs in or get your springs reset and a leaf added.
Leafs in modern utes are basically made to carry no weight and be comfortable, down side to this is as soon as you add weight they sag a lot and sit on the second stage.
With leafs its really important to have the right spring rate for your weight.
BarKer
My thinking.... If you got constant weight on the back then you'll have to upgrade the leaves by buying new or getting the existing ones upgraded.. For the occasional load airbags could be an option..
