2005 Challenger 4wd light + not engaging
Nick Marzi
I bought a 2005 Challenger LS and when testing the 4wd I found that 4H does not engage, 4L engages, 4wd green light is constantly flashing since I took it back to 2H (it is definitely working in 2H, can feel it).
Looked with Google and apparently the green flashing light is a known Mitsubishi issue, even with other models (triton, Pajerp, Montero(in the US,I guess)).
I'm looking for someone with direct experience on same or similar model to mine.
Stupid Flanders
Hi Nick
Is this the current model style challenger or the older style. Brothers did a similar thing on the current model and it was a fuse issue.
Good luck.
Nick Marzi
IT'S A 2005 MODEL, I said.
Anyway, turns out the 4H was also engaging (did not steer enough to feel it).
So, 4wd working fine, but green light on dashboard flashing randomly.
Also ABS light turning on after a few km/brakes.
I computer scan has found 2 faulty 4wd sensors; ordered and to be replaced.
Apparently due to 4wd not being used much or at all by previous owner.
Apparently ABS fault is a cascade effect of the 4wd... we'll see.
Had a look in Google and it appears such sensors are a frequent issue on Challanger and similar models.
Stupid Flanders
Manners not a strong point?
2005 is not a model number it's a year of manufacture.
I asked which model as 2005 is around the model change from the old one to the new one. Given I was at the airport on the mobile I was not about to start paying for data download to google which model it was.
03hilux
I think Stupid Flanders' question asking, " Is this the current model style challenger or the older style." was a fair question. Much unlike your response. People would be more co operative in suggesting possible causes if you weren't so abrupt with them.
I would say that not everyone is up to speed with what shape vehicle was released in what year.
And just for those wondering what model is what; Mitsubishi Challenger - Wikipedia, the free encyclopedia
woosh73
the 4wd flashing light !!
I had this issue with my 2003 mitsi challenger LS. the solenoids are a bit of a crappy design as the female connector is under the male( no jokes please)so when water gets in there if sits in the female side .mine was flashing but still engaging after extensive googling and forums . I cleaned the terminals and filled the terminal with connector grease ( electrical grease- if not you could start a fire) . problem fixed. next step is probably shielding it later or even inverting the plug or turning them over 90 degrees who knows but at this stage all good.
03hilux
Some good advice there.
Nick Marzi
4x4 light update
Challanger 2005 LS auto (older model)
Update on the "green 4wd light" + ABS light problem (both on): solved.
Too car to dealer, who had it checked by mechanic.
Mechanic plugged in tester to on board computer (didn't know about this thing... so ignorant I am...).
Run test and turned back 2 ABS codes: 26 (Free Wheel Engage Switch Circuit) and 25 (4wd Detection switch circuit).
To sensors to be replaced; advised that ABS warning was consequence of 4WD sensors; however, safe to drive while waiting for the spare parts.
NOTE: a clear but not loud noise, like a whistle or a metal part scratching against a rotating part, could be heard at all times (in neutral, 2wd and 4wd) when vehicle was moving along (NOT when stationary); mechanic came along for a drive and could hear it too.
2wks later, spare sensors arrived and were replaced (apparently, had to drop diff to access one of them); asked mechanic to have look at source of noise while car hoisted up.
He replaced sensors, took car for drive and noticed noise was gone.
Mechanic could not identify the source of the noise, however he thinks it was related to something not engaging/disengaging properly, or being partially engaged.
Sensors fault apparently due to 4wd having previously being used little or not at all (seized).
I can confirm green 4wd light and ABS light are both gone.
HOWEVER: noise is in part still there: on 2wd only occasionally and only on take off for initial say 100m, more quiet than before and then subsiding to zero; ON 4WD IS THERE ALL THE TIME AND IN MY OPINION WORST THAN BEFORE (can only hear it on smooth quiet surface, otherwise covered by background noise).
Any ideas?!
Nick Marzi
Update.
When 4x4ing a bit, then nothing for a few weeks and even gone away for work leaving car home.
Came back, used in town, then done one short 4x4 ride; all good.
Driven South, all highway, used in town, no 4x4 for few weeks.
The other day I just try on the road before getting into my driveway and... 4H not engaging (definitely, because no skidding of front tires on seal when doing a tight turn) and no green light at all. Try in low range and all ok: engaging + green light.
So insist a bit in/out of 4H, accel/decell... first got green light but flasghing... then got 4H engaging fine + green light steady.
As someone else said, looks like if you don't use the 4wd regularly it tends to seize.
THE THING I DO NOT UNDERSTAND IS why it was not engaging at all.
I was told that the green light is just a status sensor and the 4wd is mechanically engaged by the leva/stick, regardless of green light showin up or not.
So how comes I was moving leva/stick but 4wd wasn't getting in?!
The solenoid that engages 4wd in a lot of bitsamissing is a know issue as it sits under the air con drain pipe so constantly gets a drowning, a easy fix with a bit of research so I have heard and about $400 from a stealer, sorry that's meant to read dealer...
