Is there a knock sound or anything to make you think your not getting pressure??...apart from the light of course..
2002 3lt Deisel at start up oil light stays on for around 20 seconds then goes out any ideas as to why . serviced every 10k i change oil every 5k.i dont change oil filter at 5 k oil change
any help or ideas would be greatly appreciated .
Nicho
Hows the oil pressure switch, the one in my Trtion self-destructs every now and then due to engine vibrations and before it goes it starts to fail by not registering oil pressure correctly. Get the pump pressure checked and then change the pressure switch, just to be sure.
thank you all for your suggestions BUT im kicking myself in the backside i should have realised what the problem was .Some time a go i had oil on the ground in the drive way discovered that the oil filter had worked it's self loose told my mechanic about it and all has been fine up until now spoke to him today last time he serviced it he had a new guy do the service and he forgot to tell him that this filter has a history of coming loose so it wasn't tightened up that little bit extra.Thank you all again for your input from now on after it iserviced i will tighten it up that little bit more myself.
cheers
Nicho
