2 inch lift Colorado
Boehamian
Hi, I have bought a Holden Colorado RC with a 2 inch Terrain tamer lift on it without torsions.
Parking next to another colorado at work without the lift , my car doesn't look like it has lifted at all. Has anyone got any measurements from the bottom of rim the the mudguard at the front and any measurements at the back (for tray back) that I could compare to, so I can see if it has lifted or sagged?
Rhys Boehm
TerrainTamer
Hi Rhys
I would recommend that you take the car back to the dealer that you brought the kit through and see what they can do for you
I know they will be able to help you
As for the heights you may have to go back to the local Holden dealer to see if they have the height information you need
Boehamian
The lift was not put on by the dealer but by the previous owner. Also the dealer is in geelong and i am in Alice springs so is a bit hard. Anyway shall check with Holden dealer about the stock heights to compare.
cheers
Stupid Flanders
It wont lift 2" inches in the front unless they wound the torsion bars up and even if they did they tend to sag again over time.
I would order a set of torsion bars to suit the load you will have and have them fitted. Winding up torsion bars gives lift but is harsh on the ride and are a poor way of gaining height.
Once you have fitted the new bars see how it sits. It may then sit right.
jacnden
heavy duty torsion bars wont give you lift. they will just give you a stiffer ride. the only way to get lift with torsion bars is wind them up
mac_man_luke
heavy duty torsions will give you some lift because they will hold the body weight with less effort due to the higher spring rate and will sag less if wound up higher.
Colinp
Rhys,
I have a 2010 Dmax with a 2 inch lift
I replaced torsion bars and had them turned up , mine now sits 45mm higher than standard, now running bigger tyres without drama's.
I will hunt up and see if i have the paperwork still that had all the measurements before and after.
May have tossed all the paperwork out
Croozer
Measure from centre of axle to lip of guard for me and post it here! I have all the measurements at work and stronger torsion bars are suggested for any lift! Especially if you have a bar or winch and extras on the front. We sell kits complete with torsion bars and without but always recommend them.
Stupid Flanders
Yes 'heavy duty' torsion bars will give you a stiffer ride but you dont fit 'heavy duty' unless you need them to deal with heavy items like a winch and bar on the front. I hate the term heavy duty as it gets thrown around when the heavy bit is not relevant. You can gain extra lift without harshness through the use of quality steel and manufacture.
If you wind torsion bars up you are over adjusting the pre load to gain the height which makes the ride harsher. Factory settings for torsion bars generally have them in the middle of the adjustment range so you can adjust for the best std ride height.
You need to spend good dollars to get a decent ride from torsion bars such as sway a way's ones or superior engineering here in Australia. (even Superior call them 'heavy duty' when they only have a 25% higher spring rate)
But the reality is that with torsion bar front suspension what you gain in lift you lose in wheel travel as you have used the 2" you have wound it up from your down travel and you lose traction easier.
So if you are after a better ride then fit a decent set of torsion bars and leave the height relatively stock.
jacnden
a spring has a a set height, whether its a coil or a leaf or a torsion bar . if we are not talking about a lifted height spring , a heavy duty coil or a standard coil have the same height .
the same with a torsion bar. a heavy duty or a standard torsion bar sit the suspension at the same height.
there is no lift in a heavy duty torsion bar
i have a winch and steel bbar on stock torsion bars with upgraded shocks. i find the softer suspension gives me slightly more flex.
those people i know with the same car as me with heavy duty torsion bars have no extra lift and are not particularly happy with the ride
peterfermtech
I'm pretty sure my D-max was 760(F) mm front and 770(R)mm rear. After I put on an Ironman 50mm lift I had 805 and 830 and 5000 k latter it was down in the rear to 785.:eek: The spicer rear springs that replaced the Ironman have been on for 25,000 k and has stayed the same:D at 835mm. I had hoped they might sag a bit to about 810-820 so I have been considering removing a leaf.
regards
Croozer
regards
The guys are mostly correct with the comments with the torsion bars have seen a standard set wound up and later snapped (sheared completely in half) did a lot of damage to the car. :eek: As they say the heavy duty would of prevented this if correctly adjusted! rear leaf springs are set for a reason. I would not go splitting leaf packs if you are not %100 sure what you are doing. Leaf spring are a tricky exercise to get right. I have had one lift I have sold for the new Colorado say he carries all his tools and gear and this and that so he insisted 500GVM constant spring! Turns out the guy is a painter (tools - paint brushes and rollers) and the car rides like a brick and should of gone for the standard heavy duty lift up to 300GVM. Lesson learnt I spose! :rolleyes:
Rhys,
Colinp can you tell me the size of your larger tyres and did you have any trouble with them touching the front mud flaps. I have a mate with same size lift on his D-Max and is looking at fitting larger tyres but still wants to clear the mud flaps without modifying them if possible Thanks.
Boehamian
2 inch colorado measurements
Hi guys, thank you for your help.
I have gotten in touch with the original owner and all he could tell me was that he raised the front approx. 30 to 35mm at the front. He advised he just wound the torsions up so that he had 70mm of downwards wheel travel. Done my research and this is what everyone recommended.
Anyway, below is the measurements I have taken.
Left side front:
bottom of rim to mudguard = 760mm
centre rim to mudguard = 540mm
Right side front:
Bottom of rim to mudguard = 765mm
centre of rim to mudguard = 545mm
front with 70mm travel in suspension
These different measurements seem to change every time but that's what they are now.
Left back:
Bottom of rim to bottom of side lip on tray: 710mm
centre of rim to side lip on tray: 585mm
right back:
Bottom of rim to bottom of side lip on tray: 720mm
centre of rim to side lip on tray: 595mm
there is give or take a couple of mil for error
Bottom of tow bar to ground is 450mm approx.
I know that the left side has sunk a little due to a toolbox and a dual battery tray being on the right side of the vehicle in the tray(I didn't think of that when I mounted all the gear on the car, stupid me).
Also a bash plate system and bull bar being on the vehicle as well.
Do you guys think that if I put a heavier torsion in the front that it would even these measurements up a little? and how much of the ride will be compromised as I like the soft suspension and most of the off-roading I do is sand work and with a trailer on behind? Also will it help to get rid of body role?
Also I am going to put a long ranger fuel tank in it as well. Will this sag the right side more, or is all the weight fairly even? and how much do you recon it will drop, if any?
I might also be putting on an ARB steel deluxe bar or an ECB winch bar with winch a little later, just depends on if I do the cape with friends or not. Was also thinking a water tank towards the rear of the vehicle as well, maybe on a 40L or more. depending on how much room I got after the long range tank.
Also looking at putting 265 75 r16 on to correct speedo and give me a bigger lift again.
Once again thanks for all your help guys. :) :) :) :) :) :) :) :) :) :) :)
Croozer
I would do the torsion bars for sure if you are adding gear later on.
Also the measurement's for my listing are centre of axle as many rim sizes are different. I can get a more accurate idea if you measure from centre of axle to lip of guard. and I will check for you Monday and get back to you here on Monday night.
Cheers Bruce
Stupid Flanders
If a spring has a higher load rate then it will lift more.
If a spring is rated to carry an extra 200kg then that 200kg is 200kg less the vehicle can compress so it sits 200kg of force higher.
If you fit 200kg of bar and winch then it sits std.
You can of course adjust it to sit std if you like by winding the adjuster. This kind of gets back to the best option and that is not to raise it but fit the appropriate spring for the weight or setup of the vehicle and set it near std so you maintain suspension travel for traction.
Sent from my iPad using Tapatalk
peterfermtech
I still have the heavy duty Ironman torsions in the front and these for my thinking are perfect. Just the right amount of flex and stiffness giving good control on the black and not harsh on the tracks.
Any alterations on my leafs would be done by Spicers who have a heritage of spring manufacture. I am just sorting out my what my standard load will be now that the vehicle has been relieved of some of its work duties (I bought a little 2 tonne isuzu truck :))
If only springs were as simple as torsion bars. Choose your spring rate then dial in your lift.:D
regards
Stupid Flanders
Just rambling here....
Keep in mind with a torsion bar front every mm you crank it up is a mm of travel you lose. Add in a leaf sprung long wheelbase with the rear springs set to perform when loaded and you quickly have a vehicle that has very little wheel travel and gets stuck particularly on steep climbs.
I grew up in the banana plantations around Coffs Harbour where single and dual cab utes were used. They were nearly all bog stock and they were low range off road every day. Funny thing was when it had been raining heaps we used to spread fertiliser. The vehicle of choice was a Subaru wagon with rally tyres. Would beat the utes hands down. An 80 would have been better but couldn't afford the $$$.
You will get far better off road ability by using the correct springs for the load, that may well be std springs for a std weight vehicle, some exceptional quality dampers like koni or bilsteins, and a front locker.
End of ramble....
peterfermtech
Keep in mind with a torsion bar front every mm you crank it up is a mm of travel you lose. ............
I'll do some rambling to.:)
This is a comment that appears often and has got me thinking about the validity of the argument.
Adjusting the torsion bars up will give you less down travel but more up travel. So when you reach the limit of the down travel the wheel must come off the ground. However if the wheel comes off the ground the weight being carried by that wheel is transferred to the other wheels causing those springs/torsions to compress and the free wheel to remain on the ground.
Now generally a lifted vehicle will have heavier rated torsions/springs so all round the balance will mean that the wheels will want to remain level or flat compared with a softer suspension. So when one wheel is lifted the stiffness of the suspension of the other three doesn't allow sufficient flex for the wheel to stay on the ground.
So my thinking is that, within limitations, if the suspension rate is correct for the load then some lifting is not as bad for overall handling as commonly gets portrayed.
CV joints are another issue;)
end of ramble
regards
Colinp
Batts 88, rims are the dynamic Steel rims with +20 positive off set. Tyres are BfG Km2 265x75. Had to trim back the mud flaps on the front as would rub under load.
