1988 60 series landcruiser 4wd issues
Recoding
Hi!!
Im honestly asking all these questions on behalf of my boyfriend because he is to stubborn and mad to ask these questions himself. Hes just bought this landcruiser for 15k and 3 days later has realized the 4wd wont engage. Hes about to kill someone to say the least lol and is to mad to even begin thinking about how he can fix it. So im sorry if what I say doesn't make any sense, I don't know much about cars I am just repeating what everyone else says. He is pretty sure it is a vacuum issue though. When we press the button you can hear the relay but it doesn't seem to do anything. The previous owner says he NEVER except for once put it into 4wd in the 15 years that he owned it... which makes us think its just jammed up from lack of use. Also, we have manually locked the hubs and when we press the button the front shaft does spin but he claims its still not in 4wd because he cant "feel" the difference. Not sure if that has anything to do with anything but thought I might add. Any advice anyone? Or DOES ANYONE KNOW OF A MECHANIC we can take it to? That is what I would really like! my BF is just scared he will mess it up more. Thanks!!
Thanks for all the advice! just found another issue. The engine has a very hard time starting when the engine is cool. It sounds like death when starting up but then is fine after a bit. Starts just fine when warm. Does this sound like a major issue?
jack48
If front wheels turn when 4wd is selected, then you are in 4wd, you will not notice much difference driving on normal roads, only when the front wheels dig in for traction, maybe the dash light is not working, just a thought. Drive it against a tree in low range and see if both front and rear wheels are spinning, or at least one of each, if they do 4WD is working and you have a faulty dash light.
75workhorse
The way I test mine is to jack up the back
put them up on stands
engage 4wd and drive it off the stands
if you drive off the front wheels ARE engaged
simple
tremewen123
I've had issues with the vacuum actuation on mine, there are a few things to check start with the solenoids located on the firewall of the engine bay usually near the brake booster and follow the lines down to the transfer case to ensure there are no leaks. Try 4 low as well as 4 high because sometimes you may get one and not the other. The solenoids themselves can also be replaced with a reasonably cheap alternative if all else fails. Its a pretty common issue for the vac activated transfer case but it is an easy enough fix. Also if the transfer does engage you will see the light up on the dash.
Recoding
Another problem
tremewen123
Judging by the price you've paid I assume its a 12ht? If so have a look into bouncy hj61's build thread he's covered almost everything on one of those things and would be happy to offer advise
If it's spluttering and and it doesn't seem like it wants to rev then it comes good after maybe 3 or 5 seconds it could be as simple as replacing the glow plugs on a 2H or getting the air pre heat system checked for the 12HT that's if you are talking about a diesel. Just get an auto elec to check it.
Recoding
thanks
That sounds EXACTLY like whats happening. Literally it only does that the first time I start it for the day... after that perfect. I turn the key and it runs terribly for about 2 seconds then would stall. Start again and something similar happens again. have to give a bit of gas, continues to run poorly for 3 to 5 seconds then would go into tune and run perfectly. Do you think glow plugs is the problem? it is a diesel
If it's spluttering and and it doesn't seem like it wants to rev then it comes good after maybe 3 or 5 seconds it could be as simple as replacing the glow plugs if it's a diesel. Just get an auto elec to check them.
Recoding
Thanks
He has already replied to one of my posts actually but I cant find where hes telling me to look! how do I find that thread?
I just edited my previous reply but if it's a 2H motor it will have glow plugs but the factory turbo 12HT motor has an air pre heat system I know nothing about them myself I personaly let electricians take car of that side of things
jbs4wd
There is also a one way valve from the solinoids to the 4wd engage. I had a problem with mine where it got blocked. So no 4wd, Just replaced it, didnt cost much, a few $ I think. Other than that get under and see if the actuator actually moves when the button is pressed, if it tries, get a hammer. May just need a slight persuasion!!! Slowly spin wheels when doing this though, as the mesh splines (?) might be stuck also. Then change oil in gearbox and transfere.
prawns
I jacked up the rear of my Pajero and drove it off the jack to check my front wheels had power also - possibly the easiest and quickest way for confimation?
