15 inch rims on a 99 GU
Rags90mod
Righto all you Patrol gurus, got a question for you - a mate has a 99 GU (think it's a 2.8L diesel) that currently has 265/70/R16's on it and her bf spied a set of 5 Mickey T Baja MTZ's in 31x10.5R15 on black sunnies on Facebook for $700 ono.
Just went and had a look at them, 1 is brand spanking new (still has green paint on the tread) and the other 4 are pretty evenly worn (approx 10mm tread left). 4 of 5 rims have a red + yellow stripe, pretty sure they're 0° offset. The last 1 has a red stripe and had 15x8 N26 stamped on the inside so guessing it's a -26 offset. Now they're going to offer $600 & old mate seems keen.
The real questions are:
1. Whether or not the 15's will fit with no issue?
2. How much of a drama it'll be rotating in 1 brand new tyre amongst the others that are worn
3. Is it safe and/or is it going to cause issues having 1 rim with a different offset compared to the other?
4. Should they just pass on them and get a whole new set of fresh tyres an be sure of everything?
Rags
typhoeus
The 15" rims may foul the brake caliper on the front, and if the offset is wrong, they may foul the tie-rod ends or other suspension parts. you're going to have to jack her up and try the 2 different types on there and see for your self. a small difference in offset wont substantially affect handling, as long as everything clears suspension parts.
abw
15s will fit no worries (only 4.8L Patrols with the larger brakes need 16" or higher). You can't run different offsets though.
