I posted this test up on another forum today, copied and pasted below. This is a portable ARB compressor that I have permanently mounted.
I did some of my own testing today on an ARB CKMP12 that I have mounted permanently in my drawer cavity. Results below:
Tyre Size: 265/70/17 Mickey T Baja ATZ P3's
Tyres Cold: Inflated from 16 PSI - 40 PSI
Ambient Temp 16°C
Compressor temps before starting:
Compressor Cylinder head : 14.6°C
Compressor Body: 14.0°C
Tyre 1: Front Passenger side
Inflation Time: 2:15
Compressor Cylinder Head: 65°C
Compressor Body: 25°C
Tyre 2: Rear Passenger side
Inflation Time: 2:13
Compressor Cylinder Head: 78°C
Compressor Body: 27°C
Tyre 3: Rear Drivers side
Compressor Cylinder Head: 95°C
Compressor Body: 35°C
Tyre 4: Front Drivers side
Inflation Time: 2:17
Compressor Cylinder Head: 110°C
Compressor Body: 44°C
After 5 minute cool down of compressor:
Compressor Cylinder Head: 81°C
Compressor Body: 47°C (Temp rise of 3°C)
After 10 minute cool down of compressor:
Compressor Cylinder Head: 57°C
After 15 minute cool down of compressor:
Compressor Cylinder Head: 43°C
Compressor Body: 45°C
Test finished, had to go and do some real work
Airline temp at my rear quick connect never rose above 32°C, the compressor head cools quite quickly as can be noted above with a near 30°C drop in 5 minutes. Quite low ambient temps on the day of the test would have helped here also. The inflation times were pretty similar across all 4 tyres which shows the piston and compressor seals can withstand the generated temps no problem. Note: Also the temps recorded were taken from various places on the head and body, with the highest being recorded, not an average, some spots were 10-20°C cooler.
That's why I'm in the market for a new one. The switch on the cheap ebay one I had fell to pieces and now even after switch was replaced keeps shorting out when using it.
I have run an air tank before, complete waste of time IMO.
Cheers Andrew
Great honest information right there, so it pumps them up consistently in about 2minutes 15 secs
May have to look at one myself - my Thomas Big Red has faithfully served me for about 12 years but can't seem to find a supplier of those
cheers
Yep, that's the key word, "consistently" some out there will spruik the large figures on inflation rates, but the cheapies soon start to lose their compressing abilities as heat and time take their toll. I have been running this compressor for about 12 months now and it's still as good as the day I bought it. I've had my share of cheapies and baulked at paying the ARB price, but it's like chalk and cheese. Just wish I had bought the twin one now![]()
Yep I'd agree an air tank is a waste of time, some say they want it for running air tools, I struggle keeping air tools going with an 80 litre twin cylinder compressor at work, can't imagine they'd be much chop with a small 3 gallon tank. I know of someone else who fitted a tank recently and stated it was a waste of time.
See how I go! But the gear Im setting up is not just your normal 4x4 stuff and runs all braided lines and is super compact. I will look at the endless air pump system when I do the chev conversion. Its just an experiment at the moment. Endless air with a tank a mate had worked all the air tools fine even his big rattle gun. Not really for all the tools but the system should do my 35's in a flash with not heating up to much.
I can still see my father and g/father pumping up 4x4/truck tyres with a twin barrel manual pump. yeah; those up down up down things. People were naturally fit then. And I guess they used it on the occasional tractor tyres also.
