12v lighting help
Kirkster72
I purchased a led (toggle) switch & bugger me I cant get the switch to light up when the switch is on, the switch is for turning my driving lights on when high beam is on, so basically its an on/off switch, ive tried playing around adding an earth wire but no success can anyone help?
Cheers Bryan
billolga
Just keep in mind that LED is for light emitting DIODE & a diode only works one way sort of like a one way valve. The switch can work but the LED in it mite not.
How have you been wiring it in Kirkster?
2 would be +12V from your high beam for activation.
3, relay activation
6 connect to a +12V when your parking lights are on
7 and 8 jump them together and connect to a good ground point.
Looks like the lights are internally switched, except for dimming.
If I'm wrong, apologies and maybe someone with more experience can correct me.
Hope that helped mate.
Chris
Formerly Screamin TE
