12v expresso coffee makers.
dno67
Forget the 12v.:D
A white Russian, flat white.
silkwood
Plus 1 for Aeropress and a Porlex grinder. Not really into harsh espresso's much. Prefer to actually taste the coffee. Aeropress or a pour over method do it for me, though pour-over can be a little slow and easily gets cold when camping.
brianless
If you need 1000W for a fast brew it doesn't matter if it's 12V or 120V, you'll still be drawing 1000W.
So, 12V input, 1000W output means 1000W/12 = 83Amps
Use an inverter to get 1000W output and it will draw 1000W (actually more due to conversion losses) from your 12V, so still 1000W/12 = 83Amps
Are you in that big a rush that you can't stop to fire up a stove? What, takes maybe 2 minutes to boil a cup of water? You can find cheap machines following this espresso review.
Cheers,
Brian
Gavo
As someone who really only likes proper barista expresso, I've found the bellman cx25p works a treat.
It's pretty much a mocha pot, but has pressure gauge for coffee. Also has a decent steam wand which is what makes it so good. Bellman-Espresso-Maker-Steamer-CX25P.jpg
airthies
Holy thread revival Batman!!! :eek::D;):cool:
Id recomend the Airopress whether you off grid or plugged into the mains. simple, quick, efective, what more could a body ask for? ( apart from more coffee...) kettles on BTW ;)
habana
Use an inverter to get 1000W output and it will draw 1000W (actually more due to conversion losses) from your 12V, so still, 1000W/12 = 83Amps
Cheers,
Brian
Out of curiosity I looked up the power rating of a marine battery - about 60 amp-hours. Roughly speaking based on my typical boil time with a tabletop 1200W kettle, boiling just a few liters of water (at any voltage/amperage) would be enough to completely kill the battery, so bear that in mind as well...
What’s wrong with using gas to heat water, there’s a gazillion ways to do it....
Warby
Saw these a while back thought it looked interesting but no idea if its any good
https://www.wacaco.com/collections/shop/products/minipresso-ns
Don't get the minipresso - that's the old version and has been superseded by the Nanopresso, which addresses issues the previous version had with leaks and failures.
I have a Nanopresso and love it. I also have an Aeropress and love that too.. both are a bit of stuffing about to make a coffee while camping though, so it's worth spending some time on YouTube getting familiar with them.
sharkcaver
x 2. Not just x 2 on the comment, but I have 2 nano's. One in my camp kit (with barista kit) and one in my work bag (with nespresso adaptor)
One day when I get rich, I'm going to grab a delter press to see what is more convenient.
A 1200W Nespresso machine pre heats in 25 seconds
Doing a single short shot takes 20 seconds.
So do a calculation on 45 seconds @ 1200W.
I don't think you will use 30AH of battery in 45 seconds!
dusta77
It's pretty much a mocha pot, but has pressure gauge for coffee. Also has a decent steam wand which is what makes it so good. View attachment 66190
best $240 i spent two years ago and i use mine everyday at home .Solid bit of kit
LurchWA
I use a Porex grinder when using beans or just buy a heap of small packs of ground coffee in different varietys and use them in a percolator.
Havent come across a variety that cant be killed with sugar yet...........except Blend 43!!
