12v Acc Outlet and Smart Charger
Ranger_Scott
Okay, I have 2013 XL and had a 12v acc socket put in the tub, basically to run a fridge and also an ArkPak. Now, when I plug the Ark into the socket, it charges, albeit slowly. And when I plug the fridge into the Ark, the fridge runs fine, but the Ark seems not charge, ie, the fridge would seem to draw the same power from the Ark as the Ark does recharging from the 12v socket. This is strange, as the fridge only draws 2 amps (tested) and the Ark charges at 7 amps from the socket (from spec sheet).
Now I tested it on a trip back from Dubbo last week (4.5 hours for me), I put a double adaptor into the socket so I could run both the fridge and also charge the Ark from the same socket. When I got home, the Ark had been charged by 18 amps (should have been approx 4.5 hrs x 7 amps = 31 amps) and also had the fridge temp go from -6 to +19 with the insufficient voltage warning light flashing.
My question is, is the output from the 12v socket variable due to the smart charging system (which it would seem from the above), which means I need a DCDC charger installed to ensure a constant charge to the sockets? I thought that when an accessory was plugged into a socket, it would draw the amount required from the battery and the alternator would adjust the charge to the battery?
Sounds like too much load for your outlet
Your fridge might run with 2 amps but they usually spike up around 6 amps when cycling on
Plus it will lose amperage (voltage drop) over so many metres. I would run 6mm squared cable {fused at the battery)/down to the back.(or maybe the next size up)
Anderson Plug the ARK Pak to it , with solonoid to protect the main battery, then run the fridge off the ARC Pak..
Use the original plug for lights ,acc etc
I gather no duel batteries up front..
Ranger_Scott
Thanks guys... did actually think it was too much load for the outlet.
And one prob with the PX, there's no room under the bonnet for a dual battery! Always joke that it's a 5 cylinder as there was no room to put a 6th one there.
Chatty
Your fridge will draw more than 2 amps on average - it might be 2 amps when it's not actively cooling but when cooling it will be possibly as much as 10-12 amps.
As Swaggie said - run heavy cable from the main battery to an Anderson plug in the tub which could be mounted on the side of the tub.
Cigarette lighter sockets aren't designed to deliver decent currents.
If the Arkpak doesn't have a built in charge controller, you might want to consider using a DC-DC charger. They can cope with variable input voltages.
mac_man_luke
Do you still have smart charge turned on? if so get it turned off.
Its a nightmare and will destroy your starting battery too buy being kept at about 50% charge!
The socket in the tub has a nice thick power cable run and should be fine to charge an arc pack or run a fridge.
Believe its rated at 20amps
Hi mate
Are you assuming there's no room or have you been told by a 4wd shop .. It's amazing what they can move around to get at least an 80amp hour batt in there..
mac_man_luke
Hi mate
Nup no room in the rangers for a dual battery, well bigger than a motorcycle battery. 55ah yellow top fits under the rear seats or there is an under body mount but gets expensive for a smallish battery. Only option is in the tray or an arcpak setup.
and still wont solve the issues of smart charge which makes the alternator only charge what it really needs to or under braking - voltage will often sit at 12.5v for most of a trip other than the first 30 seconds with smart charge enabled. So you either need it disabled or a DC/DC charger.
With it disabled you will get a nice 14.5v most of the time with a minimum of about 13.8v
Ranger_Scott
Thanks for all the replies. HEard disabling it can affect fuel economy... any idea how much. And any other issues when it's disabled?
mac_man_luke
not noticeable
Cost of shorter battery life is likely more than the extra fuel used.
Lots of dealers were doing it pre-delivery in the end just to prevent flat battery issues.
