12v 240v inverters and chargers
CHUAH
Hi,
I have question about 12v chargers and inverters...
If a 240v to 12v charger is charging my 12v battery, can I use the 12v to 240v inverter at the same time? If yes, effectively can the 240v to 12v charger run the 12v to 240v inverter if connected directly?
Thanks!
CHUAH1
Jarh73
Yes subject to the current draw of the inverter and current capacity of the charger.
Join in a circle and make a perpetual energy machine :rolleyes:
More importantly:
Why?
Justin
CHUAH
Hi Justin,
It's just that I'm connecting the charger (40amp charging rate) to my 12v battery and on the same terminals I have the inverter (1500w out put) hook up to it.... So it's all connected as one ...etc.... Was just asking if that's how it's all meant to work...
Cheers!
Sent from my iPad using Tapatalk
Jarh73
Hi Justin,
Cheers!
Ahhhhhhhhhhhhhh now I get you.
My mistake didn't quite understand.
The answer is yes you can run everything of the same battery terminals.
Just keep in mind with both running you will draw quite a lot of current.
Justin
