12 Volt Fluro vs LED
Davidman
G'day All
Looking to purchase a 12 volt light. This will be used to hang up in the tent, hang up next to the gas cooker, put under the bonnet for repairs or used in. around or under the 4B as required.
I have tried Anaconda, Rays Outdoors and a few others with nothing really jumping out at me.
I suppose what I want is a a 12 volt fluoro that throws light out 360 degrees. The ones I have seen have reflective backings and only throw light out 180 degrees or less.
Anyone bought one of these, use something similar or able to recommend something that I can purchase, and where from.
Don't care if it is stand alone and 12 volt rechargeable or needs to be plugged in to work.
Apart from drawing less power, is LED going to be any better, or offer advantages over other products that may be available.
Thanks
Vegetoast
I used to use a 240v 25w energy saver globe in one of those caged lead lights with a hook, off my inverter. Big and bright in 360 degree's. I stopped using it since we got our cree head tourchs. but for some reason I still carry it.
chris_stoffa
Try Torpedo Lights
get em from BCF or Everkool
Have got two , hang them up and they are great each end of the annex / camper.
Deeptank
G'day All
Thanks
In most cases you can pull the end-cap off (something you'd need to do when changing the tube) and then just pull the reflector out and bin it. That's what I've done with a couple of mine to get 360 degree light.
sschmez
Bunnings sell 12v compact flouros (Nelson) and the caged lead lights with a hook ..... get both and then just swap the normal plug to a ciggie lighter one.
Vegetoast
Thats a good idea but not much light compared. but still a good idea especially for safety. Also I have my rear door frames lined with led strips and a hid light off my spare tyre. I really dont have any use for it anymore.
I've always been nuts with lights and from what I've seen 12w or 60w equivalent isnt all that bright when you dont have a white roof a walls around you reflecting the light back. Mine is 150w equivalent and thats pretty good hanging out of a tree. just remember that before you buy an expensive omni directional light or 360 degrees to use outside. I dont mean for under the car or in the tent just outside.
Also an omni light in front of you is blinding and makes it harder to see the job if your like say under the car. And if you take the reflector out of your fluro your loosing more light off your job cause you now have spread light out more and thined it.
anyway I'll just keep drinking now.
croozza
I just bought a Primus 12v Flouro from Downunder
Down Under Camping*::*LIGHTING*::*Work Lights*::*Primus*::*Primus-Power Light [HL12V]
Its a 12w flouro (most are 8w) and draws 1Amp, I made a 7.5m extension cord to complement the 5m cord this one comes with so I can plug it in my large tent and move it around with ease.
Bit dear but much brighter than LEDs.
I have one of those lights, they have very good light output, except mine doesn't like the cold, I have to get it warm first before it will light up otherwise it will just flicker.
Davidman
Thanks for all the input guys. I looked in a lot of stores, Anaconda, Rays, Repco, Super-cheap etc etc. Most were about the same price, ranging between $40 and $80.
Was in Bunnings the other day, and without even looking for them, came across a display of 12 and 240 volt fluoros. I ended up picking up one of these, at the huge cost of $7. Tried it out in the dark at home and works great. Standard price at Bunnings too. It has a hook at one end and a detachable stand on the other. It did have a reflective strip down the interior to limit the light to 180 degrees, but pulled this out pretty quick as I want to use it camping, hanging in the tent, cooking etc.
Vegetoast
at $7 what can I say. bargain! I'm going to get 1 or 3. And then I'll dribble a new post after the sun goes down.
Bravo4x4
im bit late read for anyones info. I work as a mechainc so i have been working with portible LED lights for years and finally found a SCA portable LED light from supercheap for around $50 - $60 came with 12volt car charger and 240v wall charger when charged lasts for ages and i use it when working on cars all week then topup charge and use all weekend to light the whole camp site. I have been very impressed for the cost and has paid for itself.
oznog05
I also was lucky enough to get an SCA LED unit from the brother in law, great unit. I reckon I might pick up a couple of the Bunning's unit to use for spares.
