thanx andy
i appreciate your time mate,
ive got a mates manual and will try to adjust the idle up when cold. i think this can be done by disconnecting the temp sender.
i will also get hold of a vac gauge tomorrow and go over every hose and fitting again. i think im supposed to have 23? psi of vacuum.
i'm doing a lot of reading as we speak and trying to work out what to test and how.
i also have a 62 series here im wrecking so i might change the calipers over and bleed the system again. just on the subject of brakes, if i put in the booster from the 89 model 62 series, will it improve my brakes? the booster looks a little different but im told they are interchangeable. ive heard that the later models had a double diaphram booster.
just on fuel . . diesel knock is caused by air in the system. true?
the vaccum is negative pressure don't forget, just use the specs in the manual.
don't pump the pedal up and down when bleeding brakes, it just airates the fliud into millions of tiny bubbles. push pedal down nice and easy, open the nipple or fitting, bled, close the fitting/nipple, let the pedal up, repeat until no air is released. then gentley pump the pedal 3-4 times and bled that fitting one more time. then move to the next fitting. You should overhaul the calipers before you put them on, then they are done.
The booster won't improve the the braking of the truck, it will just give you a slightly lighter pedal feel, it just provides extra pedal assistance.
diesel knock can be caused by a heap of things, air in the system can be one of them along with excessive fuelling, a dribbling injector, incorrect pump timing, blocked air intake/filter etc etc
start by looking for diesel leaks and as soon as you stop the engine listen for sucking sounds around the filter, fuel lines and pump. check your water trap down on the driver side chassis rail, take it off the car and pull it apart, nearly every truck I have done is full to the brim with dirt and sludge.
often the pump primer can suck air also.
that's a good strat for you
cheers
Andy
