100series, but Which motor ?
lukensnicket
Hi People, just signed up.
I've done some extensive touring in my 90 model, 2.8litre turbo hilux and am now in need of a family wagon.
I've saved my pennies, done a heap of home work and have come to the conclusion that i'm
after a 100 series with the 1HDFTE.
I was considering buying a stock 1HZ 100 series and turbo charging it, but I've realised
there may be reliability issues in doing this.
This brings me to thinking of buying a 100 with a high mileage/dead petrol motor and
installing a rebuilt 1HDFTE.
Thoughts ?
rob_macca67
U could always install the engine out of the last 80's which is the multivalve engine (I can't think of the code but it's the same as the 1HDFTE but w/o the electronics). That way u don't have to worry too much about the wiring side of things.....
Thoughts ?
You need to decide if you want a live axle or ifs cruiser. If you are satisfied with the lift limitations of the ifs, save yourself the hassle and buy a 100 series with the 1hd fte.
80lover96gxl
i cant see any reliability issues with turboing a 1hz...... they handle boost very well
Thats not entirely correct mate.
1hz's shouldn't be boosted over 13psi max, you'll end up with a cracked head ,cracked pistons and potential bent rods.
This is more common with the 100 series as they used light pistons in that model compared to the 80 series 1hz.
Here's a pic of just 1 of 6 cracked pistons in my 100 series 1hz
That was the worst one, the other 5 were cracked from 1 side to the other and the head looked like the grand canyon.
Boost and pyro are of the ut most importance if turboing a 1hz.
I had mine rebuilt using 1hz-t pistons made for the rather rare factory turboed 1hz to handle the boost better.
Back to op, if you want the best of both worlds ie turbo diesel live axle 100 series, see if you can find one that has had the 1hdtfte conversion done, they are out there and many say what mr toyota should have done in the first place, 1hdtfte live axle 100 series.
hulsty
All 100 series are IFS, the 1HZ is only in the 105 series which is live axle and has the small gearbox too.
crtx
Yep also keep around $4000 for gearbox / transfer clutch few other bits when your R151 lets go on you...
aim for a H151F conversion.
deepop
Like your thinking - Go the high k/dead petrol motor. Has the bigger and better H151F already, live axle (if you want that). If you're happy with the IFS then definitely get a factory turbo diesel in that model (much more expensive though - but then what's the cost of a conversion for a 105?).
MatOZ
Thoughts ?
Just remember 1HD-FTE is electronic engine. You will need the whole wiring loom and ECU if you plan to install it into a 1HZ or Petrol model. Also gearbox and clutch compatibility might be a issue. If you get a 1HZ gearbox to fit, it probably wont last behind a 1HD-FTE.
Personally I would look at a factory 1HD-FT 80 series if you don't have the cash for a factory turbo 100 series. A lot cheaper, live axels F&R, slightly smaller body and track, but still carry the same wheel base.
I have done engine conversions and they can end up costing $$$ for the right outlay.
Also consider some insurance companies wont touch repowered vehicles.
BTFIVO
The 100 or 105 series with the 1VD-FTV is becoming popular. What about that? I would kill for a 105-1VD-FTV. In hindsight, is what I should have invested my hard-earned on. But I will make the 76 as comfy as I possibly can.
lukensnicket
Thanks for your help lads.
I'm keen to have coils front and rear, as my old lux had leaves all round and i ended up
vibrating my way around oz on my year off, due to the corrugations.
I've no interest in IFS as I still have post traumatic stress from owning a subaru brumby years ago.
I'll keep ya posted, thanks again.
lukensnicket
Hi lads.
Appreciate your input, as now, after a little homework, I've more questions…………..
- Will the H150F box (has lower 1st+2nd for Yaris driving Mrs/steep suburb combination……..) fit onto the 1HDFTE's bell housing, if so are there fly-wheel compatibility issues ?
- Will the H150F box fit onto a part-time 4x4 H1FA transfer, or am I better off fitting a part time kit to the original unit ?
- will I have issues with box and/or transfer sticks striking the body during operation in a 100 series body ?
- If I went with the H1FA (part time) transfer, would I need a modified transfer cross member to ensure correct alignment/positiion ?
- Will the 1HDFTE + H150F box + H1FA combination's final drive suit the 4.3:1 diffs ?
I've no issues if the final drive's on the low side, as I eventually intend to run 33 inch tyres.
Any help would be appreciated!
thanks
Luke
Gavo
Sorry to go off topic a little, but imo this guy has it worked out.
http://www.australianimages.com.au/conversion/
1vd into a 100 series. Oh yeah! That's a dam fine Toyota there. Looking at his build, you could buy a gxl 100 with either a blown motor or high kilometer petrol for cheap. Spend 15g on conversion and still be ahead of a turbo diesel 105.
Obviously there are a million other things to take into consideration as well.
Just thought I'd share what I thought was a kick arse 100 series with an even sweeter motor! (I've got a 1vd and love it)
No man ever cut himself bearding!
mrdenn1s
I'd grab a 105 series:
- Live axel so better off road
- 4 speed gearbox which is much tougher that the 5 speed in the IFS model
- 6 cylinder petrol that is 100% bulletproof. Timing chain instead of belt so no need to ever change it. More torque at takeoff than the 1HZ has peak.
Probably the best packaged Cruiser made. Save your coin over buying an overpriced diesel. No advantage on or off road. More expensive to fix and maintain,
Mr Rum
4x4 Earth Legend
I tend to agree.
Unless you're traveling into really remote areas where diesel is the only available fuel, and where petrol vehicles seem to have more problems setting spinifex on fire due to their hotter exhausts.
rob_macca67
I tend to agree.
One of the reasons I've always gone for Diesel is the range (kms) u get from Diesel when compared to Petrol. It's a Big advantage for remote touring only really, otherwise there's enough fuel stations to now to cater for vehicles that don't necessary have the big fuel tanks.... We did come across a couple crossing the Simpson solo a few years back and they were driving a V8 100's Cruiser. We stopped to speak to them and they had travelled pretty all over the country in their Petrol V8 Cruiser w/o any issues. They did have LR tanks which allowed them to carry some 265ltrs of fuel, so even with high fuel consumption, they still had a range of around 1000kms..... U just have the $$ to fill it up when u need to.......
The issue of spinifex is a big one but this too is an issue for diesels as well, especially the modern Diesels that have DPF's installed that need to do burns every now and then....
BTFIVO
Diesel all the way. Range, efficiency, torque to haul the heavy weight with added economy, diesel stores better, smells better, sounds better, chances of a trucky being able to shed some fuel if you ran out remote is higher than a petrol car being able to do so. You'll see 20L/100 loaded up from a petrol Cruiser. Yuck. Engine - 1HDT or 1HD-FTE. (Of course 1VD if you can have it).
I would only have a petrol if it was a weekend warrior, short trips, circuits etc. Aka - Jeep Wrangler or LSX conversion.
mrdenn1s
That's almost the most innacurate post I've seen on these forums.
1HZ peak torque < 1FZ torque at idle
