07 rodeo cabin leak
goxu1
Hi , new here
I have an 07 rodeo 3.0 4x4 cab chassis.
Its just developed at leak in the passenger side footwell
I pulled back the floor mat and could seek water trickling down the vertical seam in the corner
Any clues where this might be coming from ?
Blue_haired_man
Hi , new here
Looks like it has rails for a roof rack? I’d say where they meet up with the windscreen or the windscreen would be the best place to look. There’s a lot of glaziers that are overly conservative with sealant.
You can generally narrow it down with the hose going over all suspect areas, making sure to try from different angles.
Cheers Leo
smitty_r51
Not sure on the rodeo but i have had similar on a mondeo (windscreen had a gap in the sealant at th bottom) and seen it on a pathfinder with the aircon pipe that runs along the back of the firewall
goxu1
I pulled the plastic trim below the windscreen yesterday and put the hose in there.
It seemed to leak more when I did that.
There must be a drain in the end of the plenum?? It could be blocked I guess
I'll probably have to pulled the inner wheel trim off to get to that
