Warning devices for water in diesel
MagicalG
I've read a couple of advertisements for devices which detect water in diesel. This seems like a great idea to me especially when having to use diesel from out of the way places.
However, they all seem to make a point of saying the device will detect water but are a bit quiet on what happens then.
Has anyone had experiences with these things? Do they *remove* the water before it enters the original fuel system? Or do they just provide a warning—if so what happens then? Do I stop and drain the tank? Then what?
This may be pretty obvious to most of you but to me it's a mystery. Help. Please. Thank you.
frosty
Very expensive and glamerous water trap. If your "that" worried about water, just buy a Cav filter with the glass bowl!!! From what I've seen, about 1/5 of the price. And you get an extra filter to the OE filter.
When i read your reply Frosty i thought WTF is he on about...Ive given the wrong link...:eek::eek:
Your right it is expensive,I rely on the buzzer in the fuel filter,Only had it there once from Dargo...:eek::eek:
Anyway this is what i meant....
ENGINE WATCHDOG TM2 Coolant Temperature Alarm, Gauge, Guardian & Sensor
LowLux
Some extract and some just warn but as the others said above, choose one that extracts. Can be cheaper and you just need to empty the bowl every so oftern instead of emptying the tank.
frosty
The Engine watch dog TM2 is a great unit!! And a reasonable price. I have a guage mounted to the thermostat in the same place mosr mount the TM2, so I don't have one. But,, GUAGES ARE NO GOOD,,, IF YOU DON'T LOOK AT THEM!!!!
The water watch system, whilst great for some applications, way overpriced!!!
They would be great for a diesel stationary moter in remote areas. For your car, a CAV filter. About $80!! And you get the bonus of that extra filter!! You just have to check the glass for water and junk.
Yep just had a look at it,looks great for $80..Goannawhere have some great stuff..
Hav a great weekend.
MagicalG
Thanks
The message from this seems to be to either (i) use the system that comes with your vehicle, or (ii) get a device which actually extracts water. This latter simply needs to have the bowl emptied every so often.
I had the impression from some of the 4WD magazines that water was a serious problem when getting diesel from outback supplies and that this would have SERIOUS consequences on a common rail diesel engine if water got that far.
Sounds like I don't need to stress too much.
Thanks all for the contributions.
MagicalG
Mr Filter
The Mr Funnel fuel filter funnel that Frankensurf refers to seems to be available from TJM and BCF among others according to Pro Quip at Bayswater in Victoria, the Australian importers.
Pro Quip are at Home Page » Pro Quip and the stuff on Mr Filter funnels is at Mr Funnel Fuel Filter Funnels » Automotive Funnel Range » Pro Quip.
BCF prices are $35 for 10 litres per minute; $70 for 19 lpm; and $99 for 45 lpm.
Frankensurf, have you got one of these? How does it go?
MagicalG
Other options
I've just had a bit of a look around following up on the replies here.
This is where I'm up to.
The water watch system from Responsive Engineering in Fyswick in the A.C.T. seems to be a water detection system not a filtration system. The details are available via Responsive Engineering | Water Testing System | Diesel Filtration | Water Watch. Water Watch FAQs are at Frequently Asked Questions on Water Watch.
The Engine Watchdog system does not, I think, detect water in diesel. Have a look at ENGINE WATCHDOG TM2, Engine Overheating Alarm, Gauge & Sensor.
The CAV fuel filter adapter Pre-Filter Assembly at CAV Fuel Filter Adapter | 4WD Systems | Gear to Goannawhere looks pretty good from where I'm sitting. As this web site says:
"The Supplementary Assembly is usually fitted in line before the factory fuel filter.
This adaptor allows fuel to travel to the bottom glass water and sediment trap first, so you can see any contaminants at a glance and drain them off before they reach the filter."
Has anyone had experience with this CAV pre-filter?
frosty
I have used them on my boat and cars and 1 of trucks runs one. It's really just an extra filter with the glass bowl. Most filters (Patrols doo) have a trap on the bottom of the diesel filter anyway. The CAV filter is an extra that you can see. The watchdog is another subject. Some dill (swaggie) was 1/2 asleep when he thought of that. Out back fuels can be a bit ordinary sometimes. But between the 2 filters and checks on the filters each morning, you should catch any nasties in time. You would need ALOT of water in your fuel to fill 2 filters!!! Remember, the water goes to the bottom of the filter.
Frankensurf
No, I don't have the Mr Funnel unit, but I have used a similar filter funnel in the past when storing fuel in steel jerry cans for trail bikes, mowers, etc.
I was reminded of it when reading an old 4x4 Action mag the other day and there was an article about fuel tank maintenence that suggested using one of these funnels to strain and reuse the last bit of fuel left in the tank after removal.
If TJM stock it, it was probably a 'Mr Funnel' that was used for the 4x4 Action article.
Big Rig
The Mr funnel set up I saw at the last four wheel drive show were expensive as. I still remember years ago we used to buyout diesel in bulk, ie 44 gallon drums and the sat up in the back yard. Back in those days the diesel was used for tractors, trucks and cars and we used the simple drum pump to transfer to either 20 litre drums or direct and we always double netted our funnel with the simple stocking. Always worked back then, what's changed now other than the fuel should be getting better?
MagicalG
Thanks
Thanks people for responding to this.
The way forward for me looks like being to do nothing in the short term, just keep an eye on gauges, etc.
Then when I'm feeling flush I'll go the CAV filter. [I have a little trouble believing that a funnel can remove water !!].
Thanks again.
Nicho
i have something similar on my 2002 rodeo a glass bowl fitting before the filter with a connection on the bottom to release water also has a push pump (by hand) if you run out of fuel you can pump out the air .
cheers
Nicho
srd4d
Ive bought a donaldsons water separator(yet to be fitted ) from 4wdsupplies.com $99 plus postage ,it comes with 2 filters,mount kit,fittings looks like a very good unit.
I dont trust my toyota contaminated fuel light/beeper in my hilux.
frosty
Put the new Cav filter in before the factory one. That way you'll still have the sedimetor sensor.
frosty
One thing to remember, if you put in a second filter/seperator, you may have to check your fuel pressure. A second filter may reduce pressure to the Injector pump. A lift pump before the filters pushing fuel through should solve that problam though.
